Z1R Front Master Cylinder Rebuild Kit Substitute
- DOHC
- Those Doe-Hawks really go!
Re: Z1R Front Master Cylinder Rebuild Kit Substitute
30 Mar 2018 10:27GregZ wrote: I can put finger over hole and pump brake lever and there will be a suction at my finger but no fluid. not a drop. I'm stumped
I agree that a clog seems like the most likely explanation. I know I had a front brake line that was so clogged that nothing came out of the far end.
If it would help, I have a spare Z1R master cylinder I can dig out to try to figure out what the fluid path looks like between the bore and splitter. But it may take me a few days to find it.
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
- GregZ
30 Mar 2018 13:53
Almost 8 hours on it today. Completely frustrated I don't have a clue
30 Mar 2018 14:02
Line collapsed causing the clog?
30 Mar 2018 15:22
- DOHC
30 Mar 2018 18:41Scirocco wrote: I would remove and clean the break line splitter.
The splitter is integrated into the master cylinder on the Z1R. It's a single piece.
'78 Z1-R in blue
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
- GregZ
31 Mar 2018 04:50
Not sure what fixed the problem, I switched brake lines and calipers, I also removed the new K&L piston Re- Installed the old oem M/C Piston. I managed to get fluid to the caliper and called it quits. Today I will get after it again and try to bleed and get brakes to function. Now I know why I stick with Z1's
- Godffery
31 Mar 2018 06:50 - 31 Mar 2018 06:54
If you would like, I can go threw your hole system. I have a small Vintage Moto business and provide a verity of updated parts and services.
Here is a link to my FB Page: www.facebook.com/godfferysgarage/
I also make Phenolic Caliper Pistons & Light weight Brake Rotors for a verity of Vintage metric bikes.
Gogffery's Garage
jstephens7@wi.rr.com
Burlington Wisconsin USA 53105
Gogffery's Garage
Godffery
tinyurl.com/yfrw4fc
tinyurl.com/yfrw4fc
Last edit: 31 Mar 2018 06:54 by Godffery.
- GregZ
31 Mar 2018 09:38
It's come to my attention that the Z1R front brake system is beyond my mechanical capabilities. I couldn't care any less if that TC ever sees the pavement again. I'm done with it
