Will I need a fork brace ?
  • pete greek1
  • pete greek1's Avatar Topic Author
19 Jan 2013 13:19
#568166
If I replace the chrome fender on my 76 LTD 900, with a fiberglass fender ?
  • Motor Head
  • Motor Head's Avatar
Re: Will I need a fork brace ?
19 Jan 2013 13:21
#568168
I would run one. I put one on my KZ even with the stock fender, made a big difference.
  • trianglelaguna
  • trianglelaguna's Avatar
19 Jan 2013 13:25
#568169
for sure you will
watch for the brace clamping and magnifying any old out of true stuff on the fork to wheel and fork to trees relation...ie....make a good eye of things before and after adding it imo
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • pete greek1
19 Jan 2013 13:36
#568171
Thanks Motor Head, & Tri., would you have a good line on where to buy one ?
  • trianglelaguna
19 Jan 2013 13:46
#568172
there is one on e-bay now and it looks like an old school ATK that is my favorite looking one..but the seller does not list it as a 900 and it can be tricky as i believe the J-model were different...
that said
fast from the past sells tarozzi ...they are a notch above 100 with tax.....I'm looking into this too
if it will fit kz1000 chain bikes to 79 it will fit 900's as the tarazzi sellers dont often list them as fitting 900's
new is the way to go
or run an ad on here
1976 KZ900
2003 ZX12R
2007 FZ1000
  • pete greek1
19 Jan 2013 13:58
#568173
Thanks again, I'll try Brian (KZ10006) first, before I go to the wanted sec. here, I've had the one on ebay, on my watch list for a couple of days now ,but it looks rough...Pete
  • Motor Head
19 Jan 2013 14:11
#568175
Have a look here at this thread, has a link to the dimension chart.
www.kzrider.com/forum/5-chassis/527940-b...the-k1-k2-ltd#532523
  • pete greek1
19 Jan 2013 14:51
#568183
Motor Head, I'll have to call them, cause the chart does'nt make sence to me, item #23-0012 says the brace will fit the 76 LTD 900 (B-1) & the 1980 LTD 1000(B-4), & item # 23-0025 says its also for the 1980 LTD 1000, but it has bigger diameter #'s for the forks, I dont think they made 2 different sets of forks for the 80 LTD 1000, as I'd also like to get a fork brace for my 80 LTD 1000...Pete
  • baldy110
  • baldy110's Avatar
21 Jan 2013 15:41
#568518
I install fork braces on every vintage bike I own. Does make a difference in handleing.
  • zukdave
  • zukdave's Avatar
23 Jan 2013 23:18
#568884
I need to add one to mine.
I've got the tapered bearing's in the neck
already good mod. but at a 100+ mph in the
light's I feel a little head shake,
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • wireman
  • wireman's Avatar
24 Jan 2013 02:22
#568907
Do you have a steering stabilizer on that 650 Dave?
A stabilizer will probably do you more good than a brace,as light as the front end has got to be getting going down the track it couldnt hurt B)
  • zukdave
  • zukdave's Avatar
24 Jan 2013 23:57
#569098
Not yet but soon.
I think a lot of it is I got a 30 + year old
wire wheel that "might" not be round any more.
I do have a spare hub to build a front wheel.
Thinkin maybe a 2x18 alum. rim to match the back wheel.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
