#%^$& Master link retaining clip
- psychbiker
23 Jun 2006 21:25
OK, my searching has revealed that replacing the retaining clip on a O-ring chain master link is pretty much a universally loathed activity.
Be that as it may, anyone have any words of wisdom (or super special success tips) on how to accomplish the dirty deed with a minimum of damage -- to self and bike?
- kwakagoose
- RonKZ650
Re: #%^$& Master link retaining clip
24 Jun 2006 07:10
Normally the clip is just a simple press and snap on. Never a problem with the clip. The problem comes pressing the sideplates together fully to enable the clip to be inserted. A pair of vicegrips usually can be used for this. Once the sideplate is on, the chain is assembled and isn't going to come apart. The clip is just extra reassurance.
- dkmk
24 Jun 2006 07:36
Basically what Ron said. The only casuality from my last 1300 KM road trip was the clip. Noticed it missing when cleaning/lubing the chain. Just cleaned the pins on the link and applied a sliver of repair putty in the groove on the pins to retain the sideplate. Hasn't moved since and should hold 'till I replace the sprockets/chain next spring. Good luck.
Northern Ontario
Zapp: "Kif, I'm feeling the Captain's Itch."
Kif: "I'll get the powder, sir."
- The Milkman
24 Jun 2006 16:10
Just remember to put the rounded end of the clip toward the direction of travel,, ie: if on top of rotation the round end if forward, if on bottom it points to the rear.
Ride safe,
Les
Ride safe,
Les
- shighley
25 Jun 2006 18:52
The other trick for assembling the sideplate is to use a small socket that fits over the pin and a beefy C clamp. You can feel the plate move onto the pin and alternate from pin to pin to keep the plate straight until it compresses the O rings and bottoms. Some master links don't have clips, just a pilot hole in the end. The idea is to swage (distort) the end so the plate can't come loose. Ride safe, Steve
\'74 Z1-A, Bought new, worn out 3 times, being ridden now
\'83 XVZ12TK, was daily driver until frame broke
\'78 KZ650SR-D1A, Son's bike, I'm the wrench (He's young)!
