1980 KZ1000 C3 Gas Tank.
- BB
11 Jan 2013 23:06
Hi All,
I am struggling to find a replacement gas tank. Does anyone know if there are compatible tanks from other years. Is there some sort of grid that shows parts compatible from model to model, year to year? Or is there a larger tank from another bike that would fit?
Thanks, as always, for the input!
BB
BB
1980 KZ1000P - The Mistress
2002 R1150GS - Matilda
- Linsk
- Ron L
Re: 1980 KZ1000 C3 Gas Tank.
13 Jan 2013 19:46
Im not sure what a c3 tank looks like.I have a 80 a4 you can find a lot of stuff on ebay you have to check every day Untill you find it. If its out there it will show up.Good luck
1980 KZ 1000 A4 1075 kit 1980 KZ 1000 st 2400 orig miles 1982 GS 1100 E sold 2017 ZX 14R
- Linsk
- Ron L
13 Jan 2013 19:52
I was just on ebay there is a used one for 75 dollars and there is 4 new ones for 950 dollars go to ebay
- Arttodd
02 Mar 2013 00:27
BB, are you looking to change the appearance of your bike? Look at the bottom of your tank and compare it with the tanks you find on E-Bay, Craig's List, ECT. Also go to Pro Caliber.com for part info for your bike then compare that info to possible candidates. its going to take some research to get a tank that will be a good replacement.
Arttodd
1979 Kawasaki KZ650 B3
Rock, Stock Old School Kaw
- Arttodd
02 Mar 2013 16:59
Do your research very well. I bought a tank that did not fit. I own a 1981 KZ1000 J1. Wanted a new tank that resembled the Eddie Lawson tank. Bought a tank for a 1983 KZ750 L3, Everything about the tank suggested it would fit. But the underside of the tank would not fit around the frame of the 1000. With luck, it will fit my KZ650.
Arttodd
