id needed
  • cronk
  • cronk's Avatar Topic Author
id needed
03 Jan 2013 14:34
#565699
i'm cleaning up an 82 kz-550 and i'm stumped on what the heck this is:
also looking for assistance on iding this exhaust pipe:
here she is from the front:
a little rough but she's cleaning up nice.
just finnished the carbs and custom made choke flaps for this carb...
1982 KZ-550
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: id needed
03 Jan 2013 15:04 - 03 Jan 2013 15:16
#565706
Is it a wire or tube / rubber hose?
If its a hose.... maybe looking at a drain line??? going to air box?? battery box??
Last edit: 03 Jan 2013 15:16 by 4TheKZ1000.
  • cronk
Re: id needed
03 Jan 2013 15:16 - 03 Jan 2013 15:16
#565707
it seems to be some kind of tube. it was loose when i got the bike so i never saw what it was hooked up to.
not sure where it hooks up to but it was run benieth the airbox. / battery box.
1982 KZ-550
Last edit: 03 Jan 2013 15:16 by cronk.
  • trianglelaguna
  • trianglelaguna's Avatar
Re: id needed
03 Jan 2013 18:43
#565756
if it is a drain tube it should end up down in the back of the engine or by the swing arm pivot...pull/bounce on it and see if anything under there wiggles...probably a drain like said...never seen one before...killer bike...super fun...quick and tough as nails...change the oil and filter and get some killer tires and brake pads and your good for the season...or two or three seasons...tough fast light....great bike
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • martin_csr
  • martin_csr's Avatar
Re: id needed
03 Jan 2013 20:21 - 23 Jan 2013 14:22
#565770
The part appears to be in the Battery-case/Electro-bracket diagram. It's listed as a Connector Pipe (92059) & from the drawing it seems that it may fit into a battery bracket (11036). Perhaps it has something to do w the battery vent?
Last edit: 23 Jan 2013 14:22 by martin_csr.
