stem bearings
- jeff12345
stem bearings
22 Dec 2012 22:11
any one use allballs bearings no directions bearings diff size seals diff what goes wear. i though i had common sense :blink:
KZ1000 Z1-R TC
- guitargeek
Re: stem bearings
22 Dec 2012 22:48I've used All Balls tapered roller steering head bearings in several bikes. It's a pretty straightforward operation to change them out, the hardest part is usually getting the old bearing races out of the steering head and off of the stem. If you can't drive them out/off, use a cutoff wheel on a Dremel.jeff12345 wrote: Does anyone here use All Balls bearings? There are no directions, the bearings are of different sizes, the seals are different. What goes where? I thought I had common sense! :blink:
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- 4TheKZ1000
Re: stem bearings
22 Dec 2012 23:09 - 22 Dec 2012 23:17
you have the old races.....should be a thinner one....that would be the smaller bearing......where did it go bottom or top?
found this.... forums.kz650.info/index.php?topic=3346.0
Last edit: 22 Dec 2012 23:17 by 4TheKZ1000.
Re: stem bearings
22 Dec 2012 23:31
I installed them. I used a short section of PVC to drive them home. Ed
Attachment IMG_0246_2012-12-22.JPG not found
Attachment IMG_0248.JPG not found
