KZ1000 Brake Upgrades?
  • kzz1king
  • kzz1king's Avatar
Re: KZ1000 Brake Upgrades?
24 Dec 2012 12:02
#564508
gorack wrote: Any advantage with the Concours fork? What year, pre or post 94? Thanks
Wayne
THE CONCOURS FORKS ARE WAY BEEFIER 41MM VS 36MM THERE ALSO SET WIDER APART SO I HAD ROOM TO SPACE THE ROTORS AWAY FROM THE HUB VERY IMPORTANT WHEN USING SPOKES. HAD TOO SPACE THE SPEEDO DRIVE OUT TOO SO IT WOULD CLEAR. THE FORKS ARE OFF A 86 CONCOURS SO IS THE LOWER TRIPLE TREE[/quote]
Thanks, I have an 86 I parted out. Have the whole front end but the calipers and rotors which I about give away :(
Wayne
Home built KZ1000 turbo setup
