KZ1000 Brake Upgrades?
- SBK Racer
21 Dec 2012 20:21 - 21 Dec 2012 20:24
First let me say I try the search option but maybe I was doing it wrong.
I was looking in the possibility of mounting better calipers and master cylinder for the KZ1000.
Any one ever try mounting ZRX1200R 6 piston Calipers on the KZ1000 forks???
If not, is there a direct 4 piston caliper that may be close to a direct bolt on?
I know the master cylinder probably will not be an issue... But I am looking to hear from those that have do it...
Thanks in advance. Luis
MOTORCYCLES ARE DANGEROUSLY FUN!!!
A good street rider uses judgment, to avoid situations that require superior skill...
A good track rider uses superior skill, to seek situations that define their judgment...
1998 KZ1000P-17 - 2004 PW80 Pit Bike - 2005 SV650R - 2006 SV650 - 2006 GSXR750 - Soon day BMW SS1000R
Arizona, USA
Arizona, USA
Last edit: 21 Dec 2012 20:24 by SBK Racer.
Re: KZ1000 Brake Upgrades?
21 Dec 2012 20:38Original owner 78 1000 LTD
- wireman
21 Dec 2012 20:50
Search under brakes,for author put the fish(hes a member here.
For date put any
For date put any
- The Fish
23 Dec 2012 10:04 - 23 Dec 2012 10:05
Heres a KZ 900 (1976) dual 6 piston, 310mm disc kit that I made. Check my other post as I have made a few big brake kits for the KZ 900. I havent found any drect "bolt on" big brake kits (with out brackets/spacers/etc) for any older forks that I work with.
Attachment KZ_6_pistons.jpg not found
Last edit: 23 Dec 2012 10:05 by The Fish.
- Old Man Rock
23 Dec 2012 10:20 - 23 Dec 2012 10:21
Holly crapola Fish... That swing arm tube diameter looks massive..... :blink:
Drag bike or other...?
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 23 Dec 2012 10:21 by Old Man Rock.
- turboking
23 Dec 2012 10:42Old Man Rock wrote: Holly crapola Fish... That swing arm tube diameter looks massive..... :blink:
Errr :blink: , I think the pic is of a set of fork tubes laying down with 2 calipers... ....my eyesight isn't what it used to be either. :laugh:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- The Fish
23 Dec 2012 12:41
The pic shows the big brake kit on 1976 KZ 900 front forks. The forks are mounted in a bench vise. Mounting the forks in a vise puts the wheel/fork assembly at an easier level to work on.
Here's a photobucket link with some kits that I have made. There's a few KZ 900 brake kits in there
s111.beta.photobucket.com/user/dgfischer...09008596104501016593
The following user(s) said Thank You: GPz550D1, SBK Racer
- wireman
23 Dec 2012 12:48Yeah ya oughta see the size of the fork tubes! :sick: :woohoo:Old Man Rock wrote: Holly crapola Fish... That swing arm tube diameter looks massive..... :blink:
- gorack
23 Dec 2012 14:32
its doable but not easy better have mag wheels for clearance issues, these are concours 1000 forks but use same mounting points as 650-1000"s
Attachment 2012-09-0112.28.35.jpg not found
- kzz1king
23 Dec 2012 16:54Any advantage with the Concours fork? What year, pre or post 94? Thanksgorack wrote: its doable but not easy better have mag wheels for clearance issues, these are concours 1000 forks but use same mounting points as 650-1000"s
Wayne
Home built KZ1000 turbo setup
- SBK Racer
23 Dec 2012 17:11
Oh you fantastic THE FISH you!!!
Now I know just what to do...
BMW S1000RR aftermarket 320mm front rotors
They are going to look amazing on the KZ1000P wheels...
Luis
Arizona, USA
Arizona, USA
- gorack
24 Dec 2012 06:32 - 24 Dec 2012 06:33
Wayne[/quote] THE CONCOURS FORKS ARE WAY BEEFIER 41MM VS 36MM THERE ALSO SET WIDER APART SO I HAD ROOM TO SPACE THE ROTORS AWAY FROM THE HUB VERY IMPORTANT WHEN USING SPOKES. HAD TOO SPACE THE SPEEDO DRIVE OUT TOO SO IT WOULD CLEAR. THE FORKS ARE OFF A 86 CONCOURS SO IS THE LOWER TRIPLE TREE
Last edit: 24 Dec 2012 06:33 by gorack.
