suzuki rims on kz
- nads.com
suzuki rims on kz
08 Dec 2012 19:28 - 08 Dec 2012 19:31
got two sets of gs rims a buddy droppped off in the driveway.
Can I modify these to fit the kz? They are nice looking wheels
AND THEY ARE LIGHT! :woohoo:
lighter
lighter
lighter
faster faster
stronger harder
boom
lighter
lighter
boom
lighter lighter
lighter
lighter
lighter
faster faster
stronger harder
boom
lighter
lighter
boom
lighter lighter
Last edit: 08 Dec 2012 19:31 by nads.com.
- wireman
Re: suzuki rims on kz
08 Dec 2012 22:08
Pictures?
- Kraz1
09 Dec 2012 01:59nads.com wrote: got two sets of gs rims a buddy droppped off in the driveway.
You're just Skeered... You ain't got a hair on your ass, for mixing the KZ & GS.... Dollar says you won't do it... Double Dog dare ya.
- nads.com
14 Dec 2012 17:56
That suzuki gs rear wheel seems to me can be spaced for sprocket alighnment
by milling a small amount off the hub face, where the sprocket goes against it.
Then make a spacer for between the hub and the swing arm.
A brake disc can easily be bolted to the right hand side of the hub,
once the spacer for it and the gap between the hub and arm.
That way I can choose the size of the disc, plus use any caliper I want.
I can't see how it couldn't happen, just make the center bolt, space it,
bolt it in.
And it better not lock up when I tighten it!~ The front looks the same
but you have to fill in the space between the hub and the forks on each side.
Alot of space there, have to be cretive how you want to finish the hub surface
on the side, make exotic spacers that give your wheel a look it should have.
Well I wannna ride too so it's back wheel, front wheel.
Basically it comes down to when I take off my back wheel,
the second I lift it off the ground if it's heavy It's not going back on.
I want something that wants to spin not stand still.
bolt it in.
- Kraz1
Last edit: 15 Dec 2012 00:50 by Kraz1.
