Brake disc interchange?
- Samwell
22 Jun 2006 06:04
I've checked Zedder and dug around and I'm trying to find out if the front brake rotors from a '79-'80 kz1000 with fit my '78kz1000a2. EBC lists nice light rotors for both machines, but the part numbers are different. I'm trying the dual disc conversion so I'd like to get a matched set if possible. thanks...Sam
PS: I've already obtained a stock caliper for the right side.
- wireman
- Visitor
Re: Brake disc interchange?
22 Jun 2006 06:51
the differance between the 78 and the 79-80 is the 79-80 rotors come drilled from factory other than that it should be bolton im pretty sure;)
