80lb difference between 900 and 1000?
- CrazyDuck
05 Dec 2012 21:51
This has been confusing me for quite a while now. I have two bikes, one is a 1976 KZ900-A4 and the other is a 1977 KZ1000 LTD (KZ1000B). There is such a huge difference in how the bikes ride that it got me curious enough to weigh them and I found a 80+lb weight difference. I keep looking at both bikes and I really do not see why the 1977 1000 weighs so much more. I'm sorry but the luggage rack and an extra muffler do not weigh 80 pounds. :woohoo:
KZ900-A4 weighs in at 483 with about half a gallon of fuel.
KZ1000B weighs 561 with the same quantity of fuel.
I am wondering if the frame is thicker on the 1000 or something.
1976 KZ900
1974 TX500
1978 TT500
2007 Aprilia SXV
1974 TX500
1978 TT500
2007 Aprilia SXV
- roy-b-boy-b
Re: 80lb difference between 900 and 1000?
05 Dec 2012 23:36
I thought my ltds weighed around 514 without airbox. Might have been the Classic with the fi removed running pods.
- wireman
05 Dec 2012 23:42
3 disc brakes,heavy ass mag wheels and sardine exhaust doesn't help matters any! :laugh:
- RonKZ650
06 Dec 2012 00:45
Something wrong somewhere. A KZ900 weighs a heck of a lot more than 480lb unless rust has taken it's toll and parts are missing. KZ650 in 1977 weighed 493 in CW test, 1976 KZ750 twin weighed 505, KZ1000 weighed 550. 1975 Z1 at 533. So a 1976 KZ900 weighs in less than all these? Doesn't make any sense. I can't find a magazine test on a KZ900, but weight loss from 1975-76 was nil I would wager, probably a weight gain if anything.
06 Dec 2012 00:54 - 06 Dec 2012 00:56
As a comparison, according to the Kawasaki FSM the KZ650-B3 weighs 211 kg (465 lb); the KZ650-C3 weighs 219 kg (483 lb). The only material differences between the two models are the braking system (triple disk on the C3; single front disk/rear drum on the B3) and the wheels (cast on the C3; wire on the B3). So the cast wheels and triple disk brakes (& related heavier torque link) weigh approximately 18 pounds more than the other set up. I assume these weights do not include any fuel. Ed
Last edit: 06 Dec 2012 00:56 by 650ed.
06 Dec 2012 01:08RonKZ650 wrote: Something wrong somewhere. A KZ900 weighs a heck of a lot more than 480lb unless rust has taken it's toll and parts are missing. KZ650 in 1977 weighed 493 in CW test, 1976 KZ750 twin weighed 505, KZ1000 weighed 550. 1975 Z1 at 533. So a 1976 KZ900 weighs in less than all these? Doesn't make any sense. I can't find a magazine test on a KZ900, but weight loss from 1975-76 was nil I would wager, probably a weight gain if anything.
Right. According the the specs, the dry weight of the 1976 KZ900-A4 is 230 kg (507 lbs).
www.motorcyclespecs.co.za/model/kawasaki/kawasaki_z900%2076.htm
and according to the same resource, the dry weight of the 1977 KZ1000-LTD is 249 kg (549 lbs).
www.motorcyclespecs.co.za/model/kawasaki...z1000ltd%20%2077.htm
Remember, these are dry weights. Add some fuel and you're up to the numbers RonKZ650 quoted.
- CrazyDuck
06 Dec 2012 02:30
I didn't think the mags weighed that much more. I have twin discs on the front of the 900 now but the only way that I can get the bike to weigh over 500 lbs is to fill the tank. All I removed was the center stand and the original 4-4 exhaust was replaced with a Kerker 4-1. Everything else is there including the tool kit. The inside of the gas tank was rusted badly but the rest of the bike is fine.
I am glad I am not the only one scratching my head at the weight. I didn't think 480 was right either considering the 1000 was at 560 on the same scale.
1976 KZ900
1974 TX500
1978 TT500
2007 Aprilia SXV
1974 TX500
1978 TT500
2007 Aprilia SXV
- peter1958
06 Dec 2012 07:59
Does the 900 have an earlyer z1 engine in it by chance
www.kzzone.com/
- lushbaugh
- everybodys a pro......
06 Dec 2012 08:18
every time i had to push my ltd i swore id lighten it cause its a fat hog... it feels like its 650...
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- Jeff.Saunders
06 Dec 2012 08:34
A set of 4-4 pipes on a z1/kz900 weigh 40lb. A 4-1 weighs under 20lb - so that's a 20lb difference from stock. Anything else removed like center stand or grab rail will reduce the weight as well.
A Z1/KZ900 engine is about 10lbs lighter than a 77/78 kz1000 engine. Much of this is the crank, but there are also differences in the transmission. Mag wheels are heavier than wire spoked wheels - not by much, but it all adds up.
- zukdave
08 Dec 2012 00:26
I'm 190lbs suited.
Me on the bike scaled 620lbs so
that puts my KZ650F1 at about 430 lbs
with wire wheels and not a damn thing left to take off.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- lushbaugh
10 Dec 2012 08:55
time to start drilling speed holes hahaha
