Banjo Bolt tension
- 3cav84a
Banjo Bolt tension
30 Nov 2012 22:20
G'day, I am fitting braided lines to my 1977KZ 1000 A1 and I have searched the Kawasaki workshop manual twice and I cannot find anywhere in it at which the banjo bolts should be tensioned at. Any info would be appreciated as I don't want to tighten them just guessing due to the hole drilled thru the guts of them, regards Neil
1977 KZ 1000 A1
Re: Banjo Bolt tension
01 Dec 2012 00:35
Take another look; it should be in the manual. Here's what my KZ650 Kawasaki Service Manual shows:
Attachment IMG_5712.JPG not found
The following user(s) said Thank You: 3cav84a
01 Dec 2012 01:14 - 01 Dec 2012 01:14
KZ1000 FSM, page 100, Table G1, Fitting (banjo) bolts, 21~22 ft-lbs
The banjo torque values are harder to locate because the torque info pages first cover engine parts before covering chassis parts which are listed separately on page 39, where "Disc brake parts" refers to Table G1 on Pg. 100.
Last edit: 01 Dec 2012 01:14 by Patton.
- 3cav84a
01 Dec 2012 04:47
Thanks very much for the info, (can't see the forest for the trees syndrome)
1977 KZ 1000 A1
