Upgraded Rear Master Cylinder
- Powerstroke_fan
25 Nov 2012 21:53
I will be putting a busa rear rim and brake caliper. The question i have is. Do i need to upgrade the master cylinder? or will my stock work fine? Anyone Running stock master cylinder? Thanks, Eric
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- Powerstroke_fan
Re: Upgraded Rear Master Cylinder
27 Nov 2012 09:19
Anyone done this?
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
27 Nov 2012 09:55
Is it known how closely the busa caliper bore size matches the stock caliper bore size?
- StreetfighterKz
27 Nov 2012 10:24
I'm using an stock rear master with a Bandit rear caliper (same thing as a Busa's) on my 1000.
It seems to work OK, but then again I'm using rearsets that use a linkage setup and shorter than stock brake pedal.
On my 900, I'm going with a Gsxr1000 caliper and master cylinder, with custom mount.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
