FRONT END KZ200
  • jhart26
  • jhart26's Avatar Topic Author
FRONT END KZ200
08 Nov 2012 21:22
#557559
I Have a vague question, I just need a little direction. I Have a KZ200 that is missing the front brake caliper. The part is real hard to find so I am just going to replace the front end. I want to be able to use the original spoked wheel and disc. how would I go about doing that?
thanks in advance
kz200 1977
Honda SL90 1969
  • wireman
  • wireman's Avatar
Re: FRONT END KZ200
08 Nov 2012 22:16
#557569
Have you checked the front end on a kz400 to see if its close? B)
Post a picture of your existing front end ,maybe we can get some ideas B)
  • wireman
  • wireman's Avatar
Re: FRONT END KZ200
08 Nov 2012 22:32 - 08 Nov 2012 22:37
#557576
Attachment ResizeofPicture133.jpg not found
Attachment user_11237_kz_start.jpg not found
Well I did some searching of the kz200 gallery and the kz400 gallery and they sure do look like the same front end to me dimensionally wise anyway,so atleast that gives you an other avenue to search for parts to do a complete front end swap B)
Last edit: 08 Nov 2012 22:37 by wireman.
The following user(s) said Thank You: jhart26
  • jhart26
Re: FRONT END KZ200
08 Nov 2012 22:51
#557577
That was a very fast response, Thanks!
here is a pic of the bike, i'll get some close ups tomorrow. I think you are right though, I'll search for the kz400 parts
kz200 1977
Honda SL90 1969
  • jhart26
Re: FRONT END KZ200
08 Nov 2012 22:52
#557578
Attachment 1977kz200kawasakimotorcycle032812.jpg not found
kz200 1977
Honda SL90 1969
Re: FRONT END KZ200
09 Nov 2012 06:14 - 10 Nov 2012 00:35
#557623
jhart26 wrote: ...I Have a KZ200 that is missing the front brake caliper....
In this picture, there seems to be a front brake caliper, and an upper brake hose, but perhaps the front master cylinder reservoir is missing. :unsure:
Good Fortune! :)
Last edit: 10 Nov 2012 00:35 by Patton.
  • wireman
  • wireman's Avatar
Re: FRONT END KZ200
09 Nov 2012 11:03
#557637
Yeah I noticed that also,but since there seems to be a lot more 400s out there than 200s I figure it would be easier to find a matched set of parts that way.
If the upper tubes are same diameter he might even be able to keep the kz200 triple trees since they fit the frame and just change everything else from there down and the master cylinder B)
  • loudhvx
  • loudhvx's Avatar
Re: FRONT END KZ200
09 Nov 2012 12:56
#557642
The kz200 used a mechanical caliper with a normal cable-type brake-lever. No hydraulics.
I liked it.
It worked surprisingly well when properly maintained, and no fluid messes. It performed better than a drum, better feel etc, and was about as reliable.
The following user(s) said Thank You: Patton
  • wireman
  • wireman's Avatar
Re: FRONT END KZ200
09 Nov 2012 21:15
#557679
loudhvx wrote: The kz200 used a mechanical caliper with a normal cable-type brake-lever. No hydraulics.
I liked it.
was about as reliable,now thats the part that scares me! :laugh:
