stock sprocket sizes
  • cjcrug
  • cjcrug's Avatar Topic Author
07 Nov 2012 00:27
#557334
What are the stock sprocket sizes for a 79 kz 1000 b3. I have 15-35 on now. I want to drop 1 tooth from stock on the front. Also what are the advantages or disadvantages of changing to a 530 chain.
79 KZ 1000 B3 LTD
Wiseco 1105
Kerker 4 into 1
Dyna s ignition
Andrews cams
81 kz 1000 csr
Wiseco 1075
  • Zedone
  • Zedone's Avatar
Re: stock sprocket sizes
07 Nov 2012 06:10
#557354
Hi Cjcrug,
I'm thinking 15 / 33 was stock for your bike (off the top of my head). I did a 530 conversion on my bike, the reason was for less chain weight, better availability of offset drive sprockets (for us running bigger rear tires/swing arms) wider selection of availability & colors.
One thing I discovered is, there is very little difference in chain width. In some cases a 530 (o-ring) pin will be slightly wider than a 630 (non o-ring) pin. I thought (assumed) I would gain a small amount of frame clearance going with a 530 o-ring but was wrong.
Assuming your stock gearing is 15 / 33, and you want to do a 530 conversion you will need to run a 530 18 / 47 sprocket set up.
Welcome to the board,
Cheers, Doug
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
  • martin_csr
  • martin_csr's Avatar
07 Nov 2012 08:40 - 23 Jan 2013 12:40
#557359
From the diagrams at PowerSportsPlus.com for the 1979 KZ1000-B3 Ltd: 15T Fr & 33T Rr.
GearingCommander ,,, Z1Ent - Converting from 630 to 530 chain
Last edit: 23 Jan 2013 12:40 by martin_csr.
