Need some expertise about front wheels
- pumps
31 Oct 2012 12:16 - 31 Oct 2012 12:18
I have this 83 440LTD belt model with 4200 miles that was exposed to fire in a house fire. Everything on the right front corner is damaged.Melted mostly. The front tire is toasted. I'm uncomfortable using the damage front wheel. I've been looking for a wheel that has numbers on it that match my wheel after I bought one that is wrong. The damaged one has the rotor on the left with a large deep hub and the rotor attaches with 8 hex head bolts. On the brake rotor side there are some numbers on the spokes . One number says " F-1096" and in another place it says " J19XMT1.85". Does your rim having such numbers on it? I assume the last number is the size but is the F number a part number or what? I messaged a guy on ebay about one and his F # is F-1057 but the other number is correct. Is this one that fits? Looks correct in the picture on ebay.Thanks.
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
1977 Yamaha XS650
2000 Kaw W650
Last edit: 31 Oct 2012 12:18 by pumps. Reason: add info
Re: Need some expertise about front wheels
31 Oct 2012 14:22 - 23 Jan 2013 12:10
The Fr Br rotor has 7 bolts.
According to the diagrams at PowerSportsPlus.com, a bunch of bikes have the same Fr wheel, including a number of 440 & 550 models and the 83 650-CSR & 83 750-Twins.
Last edit: 23 Jan 2013 12:10 by martin_csr.
- pumps
31 Oct 2012 18:32
You are correct amout the # of bolts being 7. I just guessed. It sure looks like the right one.
1977 Yamaha XS650
2000 Kaw W650
1977 Yamaha XS650
2000 Kaw W650
