Tail section mounts...
- Samwell
20 Jun 2006 03:10
I'm having trouble finding the part on kawasaki.com. What I'm looking for is the rubber mounts that hold the tail section body work in place. I have one that serviceable the other was a boogered up fix place by the previous owner. I didn't see it listed on Z1 or redline either...
thanks in advance....Sam
- no name
Re: Tail section mounts...
20 Jun 2006 13:32Please Log in or Create an account to join the conversation.
- The Milkman
20 Jun 2006 16:57
Unless you are doing a purely stock rebuild go to you local hardware store. Most have a section of drawers with lots of odds and ends things. You will find grommets in there that will work. If the bolt holes are too big they should also have nylon bushings that will fit to fill the gap. Just a thought.
Ride safe,
Les
Ride safe,
Les
- Samwell
22 Jun 2006 06:00
excellent, thanks to you both for the help...Sam
