- Thank you received: 2
Replacing kz550 mags with kz650 spoked wheels
- PtownSLUG
Thanks in advance!
81 GPz 550
- rstnick
- Thank you received: 377
Martin CSR swapped 550 ltd wheels onto his 650 CSR.
Check with him and compare notes.
Also, there's a member on the 650 forum looking for mag wheels, so if you don't end up needing your, he might be interested.
Here's a post on the subject, but I'm sure there was another after this, another member looking for mags:
forums.kz650.info/index.php?topic=8756.0
Here's the post, guy looking for mags:
forums.kz650.info/index.php?topic=8793.0
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- donthaveakawman
- Visitor
- donthaveakawman
- Visitor
- donthaveakawman
- Visitor
i have a kz550 owners manual around here something if you need me to read anything to you.
- Thank you received: 1656
Yes, not sure about the 70s wheels, though.rstnick wrote: I believe the swap would be dirrect.
Martin CSR swapped 550 ltd wheels onto his 650 CSR. ....
- PtownSLUG
It seems like it would fit. The problem is that the rear wheel hub I'm looking at getting only comes with the core hub laced to the rim. The hub cover that goes on the brake drum side does not come with the wheel, neither does the left side cover that holds the sprocket. So I would need that kz650 hub to be a perfect match with both side hub covers I already have.
I'm thinking maybe I should just take one for the team for the kz community- buy the wheels, try it out and report my findings so the answer will be out there for the next guy.
81 GPz 550
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
- PtownSLUG
The Gringo wrote: The rear wheel may fit but you are going to have an issue with the front. The 550 uses a leading axle front fork and the 650 does not. The axle sizes are different.
Damn it. Why is it so easy to overlook the obvious. Thanks for pointing that out. I think I'm just going to bag the whole idea. I like spokes but the only reason I was considering the swap was because I could get the wheels for cheap. If I'm gonna have to start looking at swapping forks and all that, I'm just not that interested.
81 GPz 550
- wireman
- Thank you received: 299
- donthaveakawman
- Visitor
- T_Dub
- Thank you received: 25
Front I'm not so sure, you might have to swap forks and brakes too.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
