Stripped Center Stand Bolt - how to remove?
- kwaker
27 Oct 2012 21:05
I attempted to remove the center stand from my 78 KZ1000A2. The left bolt came right out, but the bolt on the right hand side won't come out. The bolt keeps spinning and the threaded end of the bolt won't go through the tab. Either the bolt, the tread of the tab, or both are stripped.
Any ideas how to get this bold removed?
1980 KZ 1000 LTD (daily driver)
1978 KZ1000 (project)
Scottsdale, AZ
Scottsdale, AZ
- gengomerpyle
Re: Stripped Center Stand Bolt - how to remove?
27 Oct 2012 21:25
sharp chisel
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
The following user(s) said Thank You: kwaker
- etbike3135
27 Oct 2012 21:27
You have to turn it and press on it at the same time. I use an impact and then push it out with a screw driver.
1973 Kawasaki Z1
18 years in dragbikes
The following user(s) said Thank You: wireman, kwaker
- kwaker
27 Oct 2012 23:43
Thanks guys! Big flat screw driver, a hammer and an adjustable wrench did the trick...
Scottsdale, AZ
Scottsdale, AZ
- 4TheKZ1000
28 Oct 2012 14:40
sometimes it aint pretty but if you still have 10 fingers you did good.....LOL
