Those running clip-ons
  • DesertKZ
  • DesertKZ's Avatar Topic Author
16 Oct 2012 11:40
#554189
Trying to come up with an idea for making a fork-stop so my clip-ons won't hit the tank. It doesn't look like the stock stop is adjustable so just hunting for something quick and easy. Thanks.
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
  • NakedFun
  • NakedFun's Avatar
Re: Those running clip-ons
16 Oct 2012 15:37
#554208
Well, with my ZRX1200 lower triple, I am drilling and tapping the steering stop "blocks" for a small (4-40) button head screw, and then using the head thickness to reduce the side to side range. Just a thought.
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
  • DesertKZ
16 Oct 2012 15:55
#554211
I see what you're saying and that's an awesome idea.... I'm just too lazy to rip my front end off again. Everything's dialed in the way I want it right now. Ugh.
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
  • kzz1king
  • kzz1king's Avatar
16 Oct 2012 17:49
#554225
I just built up a little bead with the welder.
Wayne
Home built KZ1000 turbo setup
  • NakedFun
  • NakedFun's Avatar
16 Oct 2012 18:28
#554229
Well if you are really lazy, you could just buy a chunk of the door edge channel that they sell in black and cut a couple of short prices to slide over the sides of the stop that is welded to the steering tube....
Cory
1976 Kawasaki KZ900
  • OldSchoolZ
  • OldSchoolZ's Avatar
17 Oct 2012 11:49
#554321
NakedFun wrote: Well if you are really lazy, you could just buy a chunk of the door edge channel that they sell in black and cut a couple of short prices to slide over the sides of the stop that is welded to the steering tube....
Cory
:laugh: or glue hockey pucks to your gas tank
Remember, don't work on your bike so much you never ride it.
The following user(s) said Thank You: fizzer_$tfighter
  • DesertKZ
17 Oct 2012 13:03
#554332
Or remove the tank completely lol.
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
  • lushbaugh
  • lushbaugh's Avatar
  • everybodys a pro......
17 Oct 2012 21:31
#554405
im running drag bars so i just sleeved my stop knob with thick rubber hose, if that didnt work i was gonna tap it and put a big nut on it....
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
  • rabies
  • rabies's Avatar
  • holla
23 Oct 2012 11:19
#555353
i had clip ons. they hit the tank. so i banged in the tank.
you could tilt them out farther so they dont touch at all. depends on teh angle you have them at.
as for clip ons all together. i had back surgery last year so i couldnt hack it. i ditched them for more of an upright bar (dirtbike handle bars)
"boy its hot out.....oh..my bike is on fire"
  • damarble
  • damarble's Avatar
23 Oct 2012 12:59
#555364
I just set mine out to where they don't hit. I was able to gain a hair more by rotating the switch housings just so. It isn't optimum and puts a little strain on the outside of my wrists but I'm making do for now, it's only temporary until the USD front is on. Considering denting the tank for clearance at that time.
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
