air assisted forks..
- kzcafer
13 Oct 2012 20:39
Im sure this has been a topic before but here it is again. i have a 1981/82 kz1100 with the air assisted forks and shocks on the rear.. the rears are fine but the forks always seem to leak the air out of them.. the seals are possibly bad and need to be replaced as well as new fork oil.. is there anyway i could put a small tack weld on the air holes to plug them and get rid of the air all together ont the front forks.. what have some other people done thanks
- 4TheKZ1000
Re: air assisted forks..
14 Oct 2012 00:02
OOOOH...that sounds like a bad idea....if you would have to service them ever again...how would you charge system....what if you still leak???? for a quick fix the downside is huge compaired to no upside. If it was mine....I wouldnt do it. Im not up on air charged forks...but there are people who can help you on tech questions....good luck
- kzcafer
14 Oct 2012 03:33
thanks.. i just need to get them looked at and have the seals replaced and then see what happens
- NZGlenn
14 Oct 2012 04:16
Hi,
Try and get the OEM seals as ALL the aftermarket ones I have tried have failed within 200 miles!
Failure has always been leaking oil.
Make sure there are no edges on the forks. Usually caused by stones etc.
Just a thought have you tried replacing the valves.
The air may be leaking at the valve?
1984 GPz1100A2
- kzcafer
14 Oct 2012 05:32
The air is definitely leaking from the splitter or valve.. i would just rather get rid of the air all together.. could i just not add air.. they are pretty squishy right now without air..
- wireman
14 Oct 2012 05:40
Id try replacing the seals and using my favorite 30 or 40w synthetic motor oil in there and see if you like it without the air
- LarryC
14 Oct 2012 10:09wireman wrote: Id try replacing the seals and using my favorite 30 or 40w synthetic motor oil in there and see if you like it without the air
I second that motion.
Larry C.
14 Oct 2012 13:24 - 23 Jan 2013 11:32
You could get Progressive fork springs & eschew the air.
Last edit: 23 Jan 2013 11:32 by martin_csr.
- kzcafer
15 Oct 2012 02:54
My plan is to add some lowering blocks in the forks.. the bike is in the shop now getting valves redone so when I get it back I will work on them.. I will ask rebuild them while I'm in there and get some new oil from them.. thanks guys
