Brake cables on USD Forks
  • ramtough_63
  • ramtough_63's Avatar Topic Author
08 Oct 2012 12:50 - 08 Oct 2012 12:50
#553074
my front end isnt ready yet but was wondering what lenghth the brake lines are
master to splitter with super bars ??
splitter to calipers??
I'm using a Les triple whith the spliter located at the factory location
ZX7 USD Forks with tokiko calipers
any help from you guys already gone through this would be great
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Last edit: 08 Oct 2012 12:50 by ramtough_63.
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Brake cables on USD Forks
08 Oct 2012 12:51
#553075
I can grab you some measurements tonight on my RWU Zx7 frontend if you want. I know the lines are all factory Zx11 (same thing as the Zx7) . That will get you close.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • ramtough_63
08 Oct 2012 12:57
#553077
StreetfighterKz wrote: I can grab you some measurements tonight on my RWU Zx7 frontend if you want. I know the lines are all factory Zx11 (same thing as the Zx7) . That will get you close.
Later, Doug
thanks doug
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • testarossa
  • testarossa's Avatar
08 Oct 2012 20:52
#553154
Does the ZX7 use a splitter? Most modern era super bikes go straight from the master to one caliper and then use a short line to cross over to the other caliper. Or they run two long lines off the master.
Too bad I'm in Kansas this week or I would take some measurements off my bike.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • ramtough_63
08 Oct 2012 21:48
#553170
testarossa wrote: Does the ZX7 use a splitter? Most modern era super bikes go straight from the master to one caliper and then use a short line to cross over to the other caliper. Or they run two long lines off the master.
Yeah uses a splitter in the center gonna tray to adapt a cover
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • StreetfighterKz
08 Oct 2012 22:06
#553173
I measured the lines on my '89-90 Zx7 frontend for you. The upper line is approximately 14" long (center-to-center) and each line out of the splitter is ~17" long.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • ramtough_63
08 Oct 2012 22:29
#553176
StreetfighterKz wrote: I measured the lines on my '89-90 Zx7 frontend for you. The upper line is approximately 14" long (center-to-center) and each line out of the splitter is ~17" long.
Later, Doug
Thanks Doug
gotta start diggin around for some stainless brake lines Hope my brother has a few lol
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
09 Oct 2012 13:27 - 09 Oct 2012 13:28
#553269
i would like to encourage u to measure your own setup before spending money.
u may have dif bars or master??
make sure u have the correct length to keep them from rubbing on any painted surfaces. this may require a slightly dif routing and possibly a hose clip of some sort.
i have done a few, and i feel the splitter is the neatest way to go about it. i currently have 2 lines directly from the master, and find it more difficult to control the lines from rubbing on painted surfaces..
hope this helps. :)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 09 Oct 2012 13:28 by mark1122.
