14T sprocket, WHERE ARE YOU?! & biggest tires?
  • wireman
  • wireman's Avatar
Re: 14T sprocket, WHERE ARE YOU?! & biggest tires?
04 Oct 2012 09:21
#552380
Its all about maintenance.
If you change both gears and chain at same time ,buy a GOOD chain and keep it clean/greased/adjusted theres no reason it wont last a long time.
Thats some tough material they use on sprockets. B)
  • jbeebe1
  • jbeebe1's Avatar Topic Author
04 Oct 2012 09:51
#552384
wireman wrote: Its all about maintenance.
Is RK a "good" chain?
79 Honda 400 Hondamatic
79 Honda CB650
81 Honda CX500
81 Honda Passport C70
others coming in and out all the time!
  • wireman
  • wireman's Avatar
04 Oct 2012 10:15
#552395
theyve got good chain,and they also have really good chain just like all manufacturers you just have to check the specs on it. B)
  • jbeebe1
05 Oct 2012 13:32
#552615
update:
www.rebelgears.com/ can make a 47T rear aluminum sprocket for the 440. They priced it at 77 bucks and 2 weeks to make it.
The price is high compared to stock, but this would be my only option to change the sprockets for better acceleration.
When the time comes, we'll see what I end up doing.
79 Honda CB650
81 Honda CX500
05 Oct 2012 15:25
#552637
Even with slightly faster acceleration from stop or crawl, a downside of lower overall gearing is higher rpm while cruising.
Good Fortune! :)
  • jbeebe1
05 Oct 2012 17:38
#552646
Patton wrote: Even with slightly faster acceleration from stop or crawl, a downside of lower overall gearing is higher rpm while cruising.
Good Fortune! :)
Yea, i'm not to worried. I live in Cleveland and the bike won't be a long distance cruiser. 65-70 will be the fastest I'll be going.
79 Honda CB650
81 Honda CX500
