best tire pressure?? Pirelli MT66
  • cas.vanderwoude
  • cas.vanderwoude's Avatar Topic Author
03 Oct 2012 04:22
#552159
hi folks,
I'm new to KZ1000 and reading through the manual for my new-to-me 1979 KZ1000 ltd, I see the recommended rear tire pressure is something like 24 psi. I have a pirelli MT66 130/90 x 16 on the rear. Can anyone help me with advice on the correct tire pressure? I live in Hawaii - its always warm here and I'm thinking 24 psi seems a bit low?
Motorcycles are like underpants - you should have one for each day of the week
  • bluej58
  • bluej58's Avatar
Re: best tire pressure?? Pirelli MT66
03 Oct 2012 09:04 - 03 Oct 2012 09:05
#552171
It should say on the tire, my Pirelli sport demons recommend 42 lbs max. , I fill them to 40 lbs cold.
They warm up while riding so check and fill them first thing before you ride.
78 KZ1000 A2A
Last edit: 03 Oct 2012 09:05 by bluej58.
  • Motor Head
  • Motor Head's Avatar
03 Oct 2012 10:07
#552183
Are you running Tubes? If it's just you, no rear rack/ trunk or other weight, I'd try 28-32 and see how it feels at the different pressures. I carry a small air compressor made by Slime, and a digital pressure gauge for small adjustments on tires. 2 psi can be felt usually.
  • bluej58
  • bluej58's Avatar
03 Oct 2012 21:49 - 03 Oct 2012 22:01
#552300
With a loaded pack and my wife I'm running some where around 350 lbs or a hundred pounds lighter if I'm solo :blush:
Am I wrong to keep them so high ?
I've been out of the loop for 20 years , back then there were mostly Dunlops, Continentals and Speed grips :woohoo:
The Dunlops got hard and Continentals buckeled, I liked how the Speed grips work on my buddies 74 900 but I never tried them.
78 KZ1000 A2A
Last edit: 03 Oct 2012 22:01 by bluej58.
