Shifting problems
- 3kz88
- Just a gearhead havin fun.
Shifting problems
02 Oct 2012 22:21
I have a 82amazing kz650 its having problems catching second gear it kicks it right back out into neutral unless i dont let off the gas any suggestions?
Mr.pink
- 4TheKZ1000
Re: Shifting problems
02 Oct 2012 22:26 - 02 Oct 2012 22:36
yep...the gear dogs are worn...need to replace...no easy fix here....
www.kawasakiepc.com/SystemSearch_Frames....332&CFTOKEN=73033243
Last edit: 02 Oct 2012 22:36 by 4TheKZ1000.
- 3kz88
02 Oct 2012 23:43
Thats what i was thinking a buddy suggested a synthetic oil could hel but i wasn't sure i could even run synthetic in a bike that old
Mr.pink
- wireman
02 Oct 2012 23:44
Oil isnt going to help ya
- 4TheKZ1000
02 Oct 2012 23:55
you need a trans guy.....you will see it clear as day when disassembled....you wont wonder if you did the right thing...will be able to see dogs are worn from across the room.....this is as common with KZ as mustard on a hotdog.
- 3kz88
03 Oct 2012 00:00
Yea. Ive done alot work on bikes but not in the tran. Region if i get the book and all the parts are they very hard to do?
Mr.pink
- 4TheKZ1000
03 Oct 2012 00:05 - 03 Oct 2012 00:09
the male dog engages with the indent of the gear on right. the leading edge of dog get worn down and a ramp is created....the same thing happens to the other edge. when you hammer on the bike it will ride up the worn (ramp) and jump out of gear. the pictue is of a race app and yours looks abit different.
Attachment gears.jpg not found
Last edit: 03 Oct 2012 00:09 by 4TheKZ1000.
- 3kz88
04 Oct 2012 19:56
Awesome thanks for your help. Can i get a smaller rear sprocket to help alittle with highway speeds?
Mr.pink
- 4TheKZ1000
04 Oct 2012 21:19 - 04 Oct 2012 21:21
Last edit: 04 Oct 2012 21:21 by 4TheKZ1000.
- fpb3rd
17 Oct 2012 16:09I have the same problem what was this link?4TheKZ1000 wrote: yep...the gear dogs are worn...need to replace...no easy fix here....
