fork air valve issue
- d40265
02 Oct 2012 20:53
once again i ask the help of the KZ guru's. i have a busted air valve on the top of my 1981 kz650 csr fork. the part number is 16126-1003 org. the replacement part number is 16126-1052. The replacement part doesn't fit the stock threads. Now em i missing something here or is there a sleeve that i need? The part can be found on eBay and the pictures show a smaller thread, so this has got me lost.
1977 kz650 C1, 1981 kz650 H1, 1970 Honda Cl-100
Re: fork air valve issue
02 Oct 2012 21:36
No eBay APP ID and/or Cert ID defined in Kunena configurationThe "replacement part number" you mention (16126-1052) is listed as being used on the KZ650-H2 & H3, but not on the H1. I do not see that the H1 valve (part number 16126-1003) has been superseded (see pic); what led you to believe there is a newer number for it? Here's one of the valves with the part number 16126-1003 tag next to it. Is that different than the one you bought? Ed
Attachment 00000_2012-10-02-2.jpg not found
- d40265
02 Oct 2012 21:47
if u look at the diagram u have brought up the small box above the red one has a valve part # 16126A. thats the superseded part that i could get. or at least that's what i came to understand. that ebay part is the one i need and i seem to have found it on bike bandit for $27.00. Is it possible that they changed fork tops mid way through the year and you have to just get the right one. thank you for getting back to me.
- lushbaugh
- everybodys a pro......
02 Oct 2012 22:52
i dont know about these forks but a few ive had have standard shrader valves in the core like a tire. if thats where the leak is change the valve core. just a thought.
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
02 Oct 2012 23:06d40265 wrote: if u look at the diagram u have brought up the small box above the red one has a valve part # 16126A. thats the superseded part that i could get. or at least that's what i came to understand. that ebay part is the one i need and i seem to have found it on bike bandit for $27.00. Is it possible that they changed fork tops mid way through the year and you have to just get the right one. thank you for getting back to me.
Kawasaki.com uses that same general diagram for the H1 and H2. When you reference the H2 model and click on the 16126A part in the box it brings up part number 16126-1052. When you are referencing the H1 model if you click on the one in the box nothing happens, but if you click on the one outside the box (16126) part number 16126-1003 pops up. It is a bit confusing to say the least. I wish you good luck with Bike Bandit. My experience with them has been that they list obsolete parts but cannot supply them. Ed
- d40265
03 Oct 2012 00:55
Lushbaugh I wish it was that easy but the hole thing broke in half. Thanks ed for the help, hopefully this works out or I'll be changing to the 78' front end I have.
- Motor Head
03 Oct 2012 01:31
Check the thread dia and pitch, it might be 10mm x 1.25 which is common. One of your local bike wreckers or a Bike Shop might have another valve. Then there also would be a good tire store, they may have one.
The following user(s) said Thank You: d40265
Last edit: 22 Jan 2013 03:07 by martin_csr.
