Tube or No Tube
  • Cardin
  • Cardin's Avatar Topic Author
Tube or No Tube
17 Jun 2006 10:02
#55149
Hey all.
I'm planning for a trip across the desert and am researching my tire repair options.
This kind of hinges on knowin wether I have tubes or no tubes in my tire. Normally, I'd look at the tire, and if it says Tubeless, I'd believe it.. but I discovered on a previous bike that the previous owner had put a tube in a tubeless tire anyway.
You got any ways of knowin wether there's a tube on a wheel or not from lookin at the valve stem or somethin?
  • RonKZ650
  • RonKZ650's Avatar
Re: Tube or No Tube
17 Jun 2006 10:18
#55150
Your wheels use a tube. Pretty much all tires are labled as tubeless, but on a tube type rim you still need to use a tube because the wheel doesn't have the necessary bead retention lip to hold the tire on the wheel.
  • baldy110
  • baldy110's Avatar
Re: Tube or No Tube
18 Jun 2006 09:48
#55290
I rode an old Suzuki SP600 from California to Belize Central America back in 1997. I used tubed tires and put in "Slime" sealant before I left. Over 4000 miles of really BAD roads and I never had a flat. Just a thought.
