530 17/38 conversion
  • KJ
  • KJ's Avatar Topic Author
27 Sep 2012 21:25
#551254
Just done a 530 conversion 17/38 its a dog, has no take off. Should I have choosen a different combo.
  • racer54
  • racer54's Avatar
Re: 530 17/38 conversion
27 Sep 2012 21:31
#551255
what bike do you have?
  • KJ
27 Sep 2012 22:25
#551271
77 KZ1000
  • StreetfighterKz
  • StreetfighterKz's Avatar
27 Sep 2012 22:29
#551273
Do you have a LTD with the 16" or a standard 1000 with the 18"?
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • Mpls ugly
  • Mpls ugly's Avatar
  • 78 kz1000 plus alot of zipties
27 Sep 2012 22:32
#551274
a you looking for better accel or top end? what other mods do you have?
two wheels not four
  • wireman
  • wireman's Avatar
28 Sep 2012 00:52
#551301
How did it run before? B)
28 Sep 2012 13:35 - 28 Sep 2012 15:42
#551379
Am thinking most earlier large Kaw fours have stock 15 tooth counter-shaft sprockets;
some with 35 tooth final drive sprocket on USA models;
and 33 tooth final drive sprocket on UK models.
To convert 630 sprocket to 530 sprocket, multiply number of 630 teeth by 6/5 to derive 530 teeth equivalency.
For example, a 15 tooth 650 = 18 tooth 530
The math: 15 X 6/5 = 18
33 tooth 650 = 39.6 tooth 530 (or say 40 tooth 530)
35 tooth 650 = 42 tooth 530
To convert 530 sprocket to 630 sprocket, multiply number of 530 teeth by 5/6 to derive 630 teeth equivalency.
For example, a 40 tooth 530 = 33.33 tooth 630 (or say 33 tooth 650)
40 x 5/6 = 33.33
An 18 tooth 530 = 15 tooth 630
18 x 5/6 = 15
Chain length:
630 pitch = 3/4" 86 link 630 86 x .75 = 64.5" 86 x 3/4 = 64.5"
530 pitch = 5/8" 104 link 530 104 x .625 = 65 104 x 5/8 = 65"
Quick estimate:
Multiply number of 630 links by 1.2 for equivalent approximate number of 530 links
Example -- what length 530 needed to replace 650 with 86 links?
The math: 86 x 1.2 = 103.2
103 link 530 is about the same length as an 86 link 630.
The math: 92 x 1.2 = 110.4 (or say 110)
110 link 530 is about the same as a 92 link 630.
To calculate sprocket diameter:
www.rbracing-rsr.com/calcsprocketdiam.html
Good Fortune! :)
Last edit: 28 Sep 2012 15:42 by Patton.
  • wireman
  • wireman's Avatar
28 Sep 2012 13:58
#551387
Maybe try dropping front sprocket to a 16 so you can keep same chain B)
  • baldy110
  • baldy110's Avatar
28 Sep 2012 14:01
#551389
I am riding a GPz1100 powered bike and I also did the 530 chain conversion. I too did all the math and thought I had it right but guess what I didn't I started with 16/38 then 16/42 then 17/42 and I ended up with 17/46. That combo for me is really a good compromise of low end, cruise and high end.
  • wireman
  • wireman's Avatar
28 Sep 2012 14:05
#551390
From what I remember of the gpz's the trans is geared a little differant from kz isnt? B)
28 Sep 2012 15:44
#551405
baldy110 wrote: I am riding a GPz1100 powered bike and I also did the 530 chain conversion. I too did all the math and thought I had it right but guess what I didn't I started with 16/38 then 16/42 then 17/42 and I ended up with 17/46. That combo for me is really a good compromise of low end, cruise and high end.
What were teeth counts on the stock 630 sprockets?
Good Fortune! :)
  • baldy110
  • baldy110's Avatar
28 Sep 2012 18:16
#551443
Don't have any idea what the teeth count was on the 630 sprockets. I took the engine and transplanted into a GPz750 frame. Never rode the stock GPz1100. I just kept putting on front and rear sprockets until I got to where I liked it.
