Switch to Metric Tires
  • mwriders
  • mwriders's Avatar Topic Author
  • if I only had a brain
26 Sep 2012 14:18
#551002
It's tire time for my bike and I've been looking at available sizes. This common question has generated some debate over in the KZ Forum. The same is probably true here, but I haven't found the thread (and I did search). Anyway, I thought I'd look for opinions from this group.
If a bike specifies 3.00-18 front and 3.50 rear tires and a person is looking for a more modern tread design, the options get pretty limited pretty fast. So, converting to metrics is an option. As I read the charts, the switch would be to 90/90-18 front and 100/90-18 rear. But options for those are also pretty limited.
The temptation is to jump a profile size to 100/90-18 front and 110/90-18 rear, both of which offer more options (such as the Shinko's that have been discussed here lately). Now the small twin guys at KZ Forum say two things about this: 1) It's not ideal in theory so don't do it, and 2) It works just fine in practice.
Does anyone here have an opinion to share?
1980 Kawasaki KZ440B (brand new eBaby)
1998 Ducati 900S (gone)
1978 BMW R100S (gone, damn it)
1975 Yamaha RD350 cafe (gone)
1986 Yamaha XJ650 Seca (gone)
1981 Kawasaki KZ440LTD (gone)
1969 HD Sportster (gone :)
1966 Honda CB160 (gone, damn it)
1965 Suzuki 80
  • Del_Herring
  • Del_Herring's Avatar
Re: Switch to Metric Tires
26 Sep 2012 15:15
#551010
A lot of tires have a spec for what wheel size to be used with. If my wheel is within their width range, I feel comfortable using the tire.
1983 KZ750-N2 Spectre
  • mwriders
26 Sep 2012 16:26
#551016
Del_Herring wrote: A lot of tires have a spec for what wheel size to be used with. If my wheel is within their width range, I feel comfortable using the tire.
The only company I've found that publishes those specs (at least on their Web page) is Dunlop.
1965 Suzuki 80
  • Del_Herring
26 Sep 2012 16:54
#551024
Yea, I guess it's a little harder to find on bike tires, but it should be close between manufacturers. If you're oon the edge of their limits, I'd double check. But you should be able to contact them and ask. They'll know, most people just don't bother changing tire sizes very much, so they don't tend to hit the limits. I jump around tire sizes like crazy on cars, and have never had a problem. It may be worth considering changing the aspect ratio if you go wider, or you'll end up with a much taller tire as well, which might cause clearance issues. I always try to stay at about the same tire diameter, unless I'm intentionally doing it to "re-gear" the vehicle, and know I have clearance. I'd check and see if they offer those tires for other wheels of your diameter, that's at least a good starting point. I've never looked into whether motorcycle wheels are of consistant width, but aside from geneeral clearance issues, that's the real concern with changing tire sizes. Too wide or narrow, and they don't seat well, and you'll get roll on them, or worst case, lose seal and have a sudden flat.
  • bountyhunter
  • bountyhunter's Avatar
26 Sep 2012 18:20
#551039
mwriders wrote: The temptation is to jump a profile size to 100/90-18 front and 110/90-18 rear, both of which offer more options (such as the Shinko's that have been discussed here lately). Now the small twin guys at KZ Forum say two things about this: 1) It's not ideal in theory so don't do it, and 2) It works just fine in practice.
I went up a size on the front because the tire was rotten and the bike shop only had that size...... the tire dragged on the front lip of my front fender. :laugh:
Had to elongate the mount holes enough to get it up a bit.
YMMV
  • mwriders
26 Sep 2012 18:33
#551044
[/quote]I went up a size on the front because the tire was rotten and the bike shop only had that size...... the tire dragged on the front lip of my front fender. :laugh:
Had to elongate the mount holes enough to get it up a bit.[/quote]
Never ran into that one, although I've made some significant ballpeen adjustments.
1965 Suzuki 80
