Swingarm suggestions.
- Mine20
- Metric Maniac
25 Sep 2012 22:23
Well, I haven't posted anything up in the build section for awhile. I keep changing my mind as far as what direction I'm going in. Anyway I already picked up a 93 gsxr front end so now I need a swingarm. I have a 78 kz650c3. Any suggestions on a swing arm that will work that will fit a 07 zx6r wheel with a 170 tire?
Thanks,
MS
Thanks,
MS
2007 Honda Shadow Custom
1978 Kawasaki kz650c2 cafe project
1979 Kawasaki 650sr possible bobber project
- wireman
Re: Swingarm suggestions.
25 Sep 2012 22:42
Id try a suzuki gsxr 750,they seem to be pretty easy to come across
- Mine20
- Metric Maniac
25 Sep 2012 23:00
That's what I've been seeing. Not sure on what year though. I see folks use older ones 88-95 but not sure if they can fit the wheel I want.
- Tomolu5
25 Sep 2012 23:04
I would guess most gixxer swingers will fit a 170 tire, but the axel assembly will likely require a custom setup
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
- wireman
25 Sep 2012 23:06
Should just need to the bearings and gsxr axle work together or just differant bearings,did you get the brake parts with the wheel?
- Mine20
- Metric Maniac
25 Sep 2012 23:32
I did get the brake parts with the wheel. That may be an issue too, it's not a floating caliper.
- StreetfighterKz
26 Sep 2012 08:10
Just a suggestion, but pick up a 88-92 Gsxr750/1100 arm and get a matching rim to your front end. Some of those 750's during that era used a 4.5" rim and are perfect for use with a 170 tire.
Unless you have a really good reason that you want to use the ZX6 rim...
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- Mine20
- Metric Maniac
28 Sep 2012 18:20
Took the dive and bought an 02 GSXR600 swing arm/shock for $80. We will see what happens.
