Just to make sure I got this right
- gpzrox
16 Jun 2006 18:40
84 GPZ 750. When getting the master cylinder ready for the rebuild, I have the master cylinder off the bar, the handle off, the plastic and rubber boot out.
Should I be able to just pull the piston right out? The diagram shows a piston stop washer it looks like, just not sure if I have to unscrew something or what not.
Another question, do most motorcycles have 7/8 handlebars? It seems like I could use another master cylinder off of brand x..... I see a few off of ZX10s for some reason on ebay.
TIA
Louie
TIA
Louie
84 GPZ750. Modded with stock Kawasaki parts: ZR-7 shock, ZX-6 coils, GPZ1100 throttle, EN454 brake, GPZ900 fuse box, etc. and non stock: Ken Sears mirrors, K&N filter, Pirelli Sport Demons.
- 77KZ650
Re: Just to make sure I got this right
16 Jun 2006 19:25
my 650 has 7/8 bars, and while looking at grips that fit it, most of the grips say they fit most biks, ZXs ect..., just ebay grips and see what bikes use the same ones as yours
07 MDP Rookie of the Year
- jbw7300
- you can't ride if your fried
17 Jun 2006 04:20
if you got the rubber off and the white plastic retaining ring off then the pistion shoud pull out unless its been there awhile:P and the alunminum (?spelling) has corodded, if you have a new piston just pull it out if not then try some penetrating oil and work it till it comes out, just make sure you clean up real good after I don't know what penetrating oil and brake fluid would do together and not sure if I would want to find out:blink:
84 kz 700 a1 sports
- gpzrox
17 Jun 2006 04:42
That is what I thought guys, thanks alot! It's been soaking in PB all night, let see what happens.
- OKC_Kent
17 Jun 2006 06:02
PB will soften and expand rubber parts. I soaked my caliper in it and forgot to remove the o-ring. The next morning there was NO WAY that o-ring was going back in, it was way too big and soft. It stayed like that too.
I guess i'm saying "I hope you have the rubber parts to replace what will be softened"
Cashion, OK
78 KZ650 B2 85,000+ miles
- gpzrox
18 Jun 2006 03:55
Yep, noticed that too, had to replace one o-ring.
Back together and working great now!
Louie
Louie
