how much air psi do my front forks take, 84 kz700
  • cott10r
  • cott10r's Avatar Topic Author
  • Motorcyclist for life!!!
18 Sep 2012 11:41 - 20 Sep 2012 16:46
#549435
Hi all, i recently purchased an 84 kz 700 & i noticed it has valve stems on top of the front forks, i was curious what air psi ranges are recommended & what the proper way to inflate is also.
2012 kawasaki concours 14
2014 suzuki gsxr 1000
2014 honda crf 250L
1983 kawasaki gpz 550
Last edit: 20 Sep 2012 16:46 by cott10r.
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: how much air psi do my front forks take, 84 kz700
18 Sep 2012 12:33
#549439
I really dont know the pressue...but if you introduce to much, you can blow the seals.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
18 Sep 2012 12:45
#549443
It is a low-pressure system...6-8 lbs pressure...use a bicycle pump...compressed air will quickly overwhelm your fork seals (as was suggested by 4thekz1000).
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Calico
  • Calico's Avatar
18 Sep 2012 14:10
#549456
The way I've gone about it is pretty by the book. If you have a good, reliable and (most importantly accurate) compressor, you can use it. Just be certain to dial it down within the pressure spec. The spec I have is for what I imagine non-neglected parts.
It reads:
"Connect a pump to the valve and pump the forks up to about 25 psi.
CAUTION: Do NOT exceed 36 psi or the fork seals will be damaged.
Slowly bleed off the pressure to reach the desired value."
Earlier in the chapter it states that the maximum allowable air pressure difference between the forks is 1.5 psi.
I hope this helps
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
  • martin_csr
  • martin_csr's Avatar
18 Sep 2012 15:40 - 23 Jan 2013 00:27
#549468
Check & adjust the air pressure w the front wheel off the garage floor.
Note: the owner's manual has the info. It may be hidden on the underside of the seat in a pull-down document case.
Last edit: 23 Jan 2013 00:27 by martin_csr.
  • cott10r
20 Sep 2012 16:44
#549916
ya i looked for an owners manual just in case it was still with the bike but there was not one to be found.
2014 honda crf 250L
