offset fork races to rake front end???
  • baborz72
  • baborz72's Avatar Topic Author
  • Not enough hours!
17 Sep 2012 09:01
#549197
Hopefully I am not re-posting an old topic here. Does anyone make, or is anyone aware of offset headset races to rake front end on a kz900z1??? These parts are commonplace in the world of Harley Davidsons and with the front ends of these bikes really needing the extra rake, surely somebody makes a set.
It'll go...or...It'll blow!
  • ramtough_63
  • ramtough_63's Avatar
Re: offset fork races to rake front end???
17 Sep 2012 10:54
#549214
the same with trees you can order raked trees for harley but I havent found a KZ person
that will even discuss it.
If anyone knows if anyone makes a set of offset races I would like to know also
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • wireman
  • wireman's Avatar
17 Sep 2012 12:53
#549233
I kind of wondered about something like that years ago for being able to switch over a bike for drag racing on the weekends for straight line running down the 1/4 mile,then be able to switch it back in a couple hrs for normal riding around town but never really pursued the idea.
I guess after after all the years of riding severely over powered streetbikes and wild rides on the old 1327 down the 1/8 mile with unraked frontends Ive learned to just go with the wheelie! :woohoo:
Attachment gagorder.png not found
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
17 Sep 2012 15:23
#549274
Go oldschool on the muther....sawsall that frame, plug it weld it back....nasty back alley fab....come on man!!!!!!!!!!!
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
17 Sep 2012 17:08
#549292
Raked trees give you less trail which mean quicker turn in and less high speed stability! These old bike are notorious for head shake and you would only be adding to it. You can go to a lower offset tree setup and calm them down a bunch. A 78 KZ for example has 60mm offset trees, a ZX has 24mm. Just doing a swap gives you more trail and hence more stability at higher speeds, not to mention the added fork stiffness and cool factor. B)
Les
  • baborz72
  • Not enough hours!
18 Sep 2012 00:14
#549382
I wasn't referring to "raking trees". I was referring to accentric bearing sets, which act the same as a raked frame. The raked triple trees are dangerous and should not be used on ANYTHING! Offset bearing races however, move the axis point and raise the amount of trail exactly the same as a cut frame. The only thing is, you don't have to butcher up a vintage frame to achieve your goal. Cost is also dramatically cut, as you don't need a fabricator or a frame jig to install them.
  • wireman
  • wireman's Avatar
18 Sep 2012 00:19
#549384
baborz72 wrote: I wasn't referring to "raking trees". I was referring to accentric bearing sets, which act the same as a raked frame. The raked triple trees are dangerous and should not be used on ANYTHING! Offset bearing races however, move the axis point and raise the amount of trail exactly the same as a cut frame. The only thing is, you don't have to butcher up a vintage frame to achieve your goal. Cost is also dramatically cut, as you don't need a fabricator or a frame jig to install them.
I never thought of that,how does it work? B)
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
18 Sep 2012 06:45
#549396
I see what your saying and yes, it is much different. The subject of raked trees come up a lot so I guess I just didn't read fully into it. It would work, provided you could find the room to get them in. Not a lot of room to move things around much.
Les
  • baborz72
  • Not enough hours!
18 Sep 2012 07:53
#549407
Yea, I was looking at mine and the head tube is much smaller in diameter than that of the Sportster. I guess I will be rakinh that baby. Now...... Add to the bottom or just notch the top and tilt'er on back????
