Tightening chain
- biscuit0229
Tightening chain
16 Jun 2006 09:31
My chain seems to have become loose. Wants to jump teeth on the sprocket when taking off in first. I'm at work... anything I can do for a quick tightening job for the ride home...
I have a 79 kz 1000 if that helps.
Huck
Huck
- Mcdroid
- Gone Kwackers
Re: Tightening chain
16 Jun 2006 09:57
Nothing 'quick fix'. Get out your tool kit...all you need is one wrench...loosen the lock nuts, screw in the endbolts to lengthen your wheel base (= tighter chain) keeping in mind both sides must be equal in length and re-tighten the lock nuts. Voila!
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- lifeliberty
16 Jun 2006 09:59
don't you need to also loosen the large axel nut and the rear brake stay? I think I remember doing that when i had my 550.
- biscuit0229
16 Jun 2006 10:24
Thanks a lot... I do maintenance at work so hey.. my tool bag is here...
Much appreciative
Much appreciative
- wireman
16 Jun 2006 12:07
definately loosen the axle nut.dont forget to put cotter pin in whe you tighten it back up.
- biscuit0229
16 Jun 2006 14:15
already tightened... however looks like won't be able to tighten again.. maybe time for a new chain. thanks for all the help... pics of my work in progress coming soon...
- steell
16 Jun 2006 15:14
Sounds like it's time for new sprockets as well
