83 GS1100E swing arm on an 82 KZ1000LTD
  • Buda
  • Buda's Avatar Topic Author
03 Sep 2012 16:31 - 03 Sep 2012 16:47
#546420
Has anyone done it? Will to fit?
Thanks
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Last edit: 03 Sep 2012 16:47 by Buda.
  • Buda
Re: 83 GS1100E swing arm on an 82 KZ1000LTD
04 Sep 2012 23:01
#546710
Nobody? Guess I'll give it a shot
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
  • TexasKZ
  • TexasKZ's Avatar
05 Sep 2012 13:08
#546831
It is a very common swap. You'll likely need some washers to use as spacers between the swing arm and frame and you will need to use Suzuki-style shocks or to redo the swing arm shock mounts for the Kawi-style shocks. You may need some spacers out back, too depending on how the sprockets line up.
I'll bet there is a thread or two about this somewhere on this site. Maybe even an article inthe file base.
