brake rebuild kits
  • poolboy
  • poolboy's Avatar Topic Author
brake rebuild kits
03 Sep 2012 13:13
#546377
Need brake rebuild kits for 1980 Kawasaki KZ 750 4 cyl ltd frt/rr master cyl.
looked everywhere, any help appreaciated, thanks. Jim
1980 KZ750H ,WG's carb rebuild, V&H 4-1 Exh ,WG wiremod, Dyna 3.0 ohm coils, Dyna-S EI DS2-2,New Bridgestones, O-ring Chain,
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: brake rebuild kits
03 Sep 2012 13:25 - 03 Sep 2012 13:38
#546383
did you try Z1-Enterprises?
they have them for 1980 750 H1
www.z1enterprises.com/ItemDetails.aspx?i...f1100&item=KL32-8053
M/C Kit double disk version (5/8")
KL32-8052
Equivalent to OEM: 43020-1023 49016-1010 43022-1001- Contains all the parts to rebuild one (1) 5/8" master cylinder. This mastercylinder is typically used only for double disk setups. Given the age of these bikes, it is worth checking that the master cylinder is correct for the bike - most of these master cylinders will have 5/8" cast into the underneath of the master cylinder. Fits KZ550-D1 KZ750E KZ750H KZ1000-A3 KZ1000-A4 KZ1000-B2 KZ1000-B3 KZ1000-B4 KZ1000C KZ1000E KZ1000G KZ1000-J1 KZ1000-J2 KZ1000K KZ1000M KZ1000-P1 thru P10 KZ1100-A1 KZ1100-A2 KZ1100-B1 KZ1300 $38.10 Ea
Last edit: 03 Sep 2012 13:38 by 4TheKZ1000.
  • poolboy
04 Sep 2012 00:10
#546517
Thanks I didn't see that, must be getting old, actually I am. 72. Thanks Bud :huh:
