77 KZ1000 stock to modern fork swap
  • floivanus
  • floivanus's Avatar
Re: 77 KZ1000 stock to modern fork swap
15 May 2016 14:40
#726583
I'm not certain, but I'd wager the stock top clamp on the zx9 is some type of 6000 series aluminum you should be able to gullwing it with a spacer and get it weld it up. Then of course it would need heat treated.
I know one person who gained his clearance by welding up a flat collector instead
Past; 78 kz1000, 83 kz550
Andrew
  • SWest
  • SWest's Avatar
  • 10 22 2014
15 May 2016 15:01
#726589
May not work but what about a 19" front wheel and spaced fender to match?
  • floivanus
15 May 2016 15:31
#726596
Ramtough did the 19" wheel with the help of either leon or les. Details are in his build thread.
But there isn't much 'modern' tread choices with a 19.
Andrew
