another fork oil question...
- heartless
14 Jun 2006 20:12
ok, did some research and am more confused than before i started...
need to replace the fork seals on my '84 KZ550-F2 (with air assisted damping) - which will obviously require fresh fork oil.
Manual states SAE 5W-20, which, from what i am reading, is not so readily available anymore.
here is where I get confused...
Some of you claim to use ATF instead, but nobody is saying which type - dexron or type F? or am i missing something???
alternatively, will hydralic oil of a similar weight work???
or am I stuck paying 3 times the money for "Fork Oil"????
Thanks in advance.
Ride Safe!
Thanks in advance.
Ride Safe!
- baldtires
Re: another fork oil question...
14 Jun 2006 20:53
I just replaced the stuff the last owner had in mine
(stinky nasty stuff)with some 10w30 and i think that it's kind of soft
ATF would be very soft,if your forks have drain bolts
in them try till you like it,but it's a little messy
some ATF will work for Dextron or F type
- heartless
15 Jun 2006 18:28
i appreciate the response baldtires...
no one else wants to chime in here??? come on guys...really need to get the seals done asap and would like to do it once and be done with it (more time for riding), it's kind of a pain to drain and refill when ya have a windshield on and you have to remove it and the handlebars to get to the fork tops....
- 77KZ650
15 Jun 2006 18:37
check this
link
out;)
07 MDP Rookie of the Year
- heartless
16 Jun 2006 05:02
i found that thread, as well as several others - but nobody says which type of ATF - "Dexron" or "F" - there is a difference between the two.
- steell
16 Jun 2006 06:33
heartless wrote:
Personally I would try 10w engine oil first, and if that was not enough damping then try 15w. I have not checked in a while but I think both are still available.
Yep there is a difference, a difference in the additive package, but it has nothing to do with using it in the forks.i found that thread, as well as several others - but nobody says which type of ATF - "Dexron" or "F" - there is a difference between the two.
- oldcoldankles
16 Jun 2006 06:41
Why not try readily available 10W fork oil. That's what I use and is specced for the KZ550-M1 and F1 measured 416mm ± 2mm below the top of the inner tube.
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
1981 KZ1000 CSR M1
1989 Corvette coupe
- KZ_Rage
- Kentucky Bourbon Barrel Ale
16 Jun 2006 06:47
sent you a pm on this as I just did my F2.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
1984 KZ550F2 SOLD!
- craigpuckett
16 Jun 2006 07:56
I used dexron in my CSR 1000 when I changed the seals and it works fine for me.
be sure to use a plastic baggie (not ziploc type) over the end of the fork tube to protect the seal when slipping it down over the tube.
