straight bars cable question
  • krifartida
  • krifartida's Avatar Topic Author
29 Aug 2012 22:44
#545562
I recently installed some straight bars on my 81 kz750 H2.
The bars that came with the bike were moronically cut, then re angled outward to resemble ape hanger bars, making the bars and the bike utterlly useless.
So on went the straight bars. Fitment of all controls was fine with the exception of some routing issues:
The clutch cable has much less space to be in, and it is coming out of the handle, then forward, and angles down and backward towards the lower triangle, and then to the frame. That U shape pointing outward is somewhat concerning. Is there an alternative? Are there shoerter clutch cables out there? is there another option as to routing?
The throttle cable has a similar route, but i think i will be able to find more room to U it under the gas tank or something similar.
The main issue is the front break line. The master cilynder is now sitting very close to the top of the fork, and has almost no clearance from the tach gauge housing and the line has to curve around behind the main light. I searched for a while for universal break lines to try and get a more flexible braided line or a shorter line but could not find anything usable.
Any ideas on all three would be much appreciated.
  • martin_csr
  • martin_csr's Avatar
Re: straight bars cable question
30 Aug 2012 09:54 - 22 Jan 2013 21:25
#545644
Z1Enterprises has a good variety & includes the measurements.
Last edit: 22 Jan 2013 21:25 by martin_csr.
  • krifartida
31 Aug 2012 19:28
#545939
Jeff at Z1 ent was super helpful and once i get the battery and make this bike actually runs i will be getting some new break lines and cable to fit the short bars.
Thanks all.
