Front Rotors
- 4TheKZ1000
Front Rotors
28 Aug 2012 21:38 - 28 Aug 2012 22:07
how many different styles of rotors were on 78 though 80 KZ 1000 front ends?
4 bolt hole
Thanks
4 bolt hole
Thanks
Last edit: 28 Aug 2012 22:07 by 4TheKZ1000.
- wireman
Re: Front Rotors
28 Aug 2012 23:33
Drilled or undrilled was pretty much it,z1r might have its own hole pattern
The following user(s) said Thank You: 4TheKZ1000
- pete greek1
Re: Front Rotors
29 Aug 2012 10:24
just mounted 78 Z1 rotors on my 80 LTD,they mounted right up...Pete
- wireman
Re: Front Rotors
29 Aug 2012 13:39Z1r rotors have the same mounting holes,its the pattern thats drilled in the rotors that Im thinking is differant from the ltd style rotorspete greek1 wrote: just mounted 78 Z1 rotors on my 80 LTD,they mounted right up...Pete
- roy-b-boy-b
Re: Front Rotors
29 Aug 2012 18:28
Alot of 650 rotors will work also.
The following user(s) said Thank You: wireman, 4TheKZ1000
- pete greek1
Re: Front Rotors
30 Aug 2012 02:36
Wireman, I was just making comment, because the rear 78 Z1R rotors have the same bolt hole pattern, but are about a 1/4 to a 1/2 inch larger in diametor than the LTD 1000, so I ended up having to buy a 78 Z1R caliper to make things work, but the fronts wre the same size, so no issues up there....Pete
- wireman
Re: Front Rotors
30 Aug 2012 05:57
No problem,I never realized the z1r had bigger rear rotor than a kz/ltd.
Ive always tried to make sure the rear brake had less power than front to avoid locking it up,Ive even been known to file vertical grooves in rear brake pads to make it harder to lock rear wheel up.
- 4TheKZ1000
Re: Front Rotors
30 Aug 2012 08:42pete greek1 wrote: Wireman, I was just making comment, because the rear 78 Z1R rotors have the same bolt hole pattern, but are about a 1/4 to a 1/2 inch larger in diametor than the LTD 1000, so I ended up having to buy a 78 Z1R caliper to make things work, but the fronts wre the same size, so no issues up there....Pete
you can tell these smaller rear rotors due to the fact they have 8 rivits holding the hub to rotor....not 9
- pete greek1
Re: Front Rotors
30 Aug 2012 12:49
4the KZ...good observation !!!!
