Leftover part--please help me find where this goes!
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
14 Jun 2006 10:11
I just replaced the front sprocket on my '81 KZ440 LTD, and I have a leftover part that I cannot remember where it goes. It is some kind of cable clamp. Does anyone here recognize it and can tell me where it goes?
Thanks.
Thanks.
West Linn, OR
- BSKZ650
Re: Leftover part--please help me find where this goes!
14 Jun 2006 10:54
looks like the brake hose clamp
77 ltd1000, current rider
76 kz900, just waiting
- lifeliberty
14 Jun 2006 11:02
is it one of the clamps that your clutch cable goes through? I think it is mounted on your frame downtube in front of your gas tank.
- hwms
14 Jun 2006 11:03
In my early days in the shop there was an old saying "if you are short of parts your in trouble. If you have too many just throw them away"
Harry
Harry
- Skyman
14 Jun 2006 11:26
lifeliberty wrote:
Yes, it should be for the clutch cable, as I had removed the cable so I could clean the front sprocket cover. I was trying to find where it connected under the cover. When I get home tonight, I will see if I can find where it attaches higher up on the bike.
It is weird, though. I don't remember having removed it. Maybe it came loose long ago and slid down the cable.
Thanks all for your help.
West Linn, OR
- Skyman
15 Jun 2006 08:36
lifeliberty wrote:
Well, I went home and took another look at the bike. I found another clamp that I think you were referring to that attaches to the downtube. That one is still in place.
No, the orphaned clamp I have is different. It has a tab with a hole so it can be bolted onto something. I just can't figure out which bolt holds it in place.
Any other ideas? Thanks.
Post edited by: Skyman, at: 2006/06/15 11:38
West Linn, OR
- fixer5000
15 Jun 2006 09:08
1978 kz650b pretty much stock
massachusetts
massachusetts
- fixer5000
15 Jun 2006 09:13
after looking a little closer i think it goes on the top left tube clamp to hold the cable in close to the forks...steve
massachusetts
massachusetts
- patmann
15 Jun 2006 09:41
You could always do as I do.. drop extra parts into the gas tank and hope that they work their way back to where they came from:P Hey !! Maybe that's my problem I'm having now!!
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
- Skyman
15 Jun 2006 10:34
fixer5000 wrote:
Okay, I'll take another look at that when I get home tonight. If that is where it goes, I was looking in the wrong area. I assumed that since I found it after having reomved the front sprocket cover, that it was supposed to be attached somewhere at the bottom. It must have come lose and slipped down long ago, and I never noticed it.
Thanks again.
Thanks again.
West Linn, OR
