Rear rim , rim locks???
  • Mgwood80
  • Mgwood80's Avatar Topic Author
24 Aug 2012 11:54
#544485
I recently had a new tire put on the rear of my 76kz400, and anx the tube blew out of it, and the tire place that put it on told me that i had no rim locks and there was no lip on the rim either im kinda of new to this. So what can i do add the rim locks and it should be good??
  • wireman
  • wireman's Avatar
Re: Rear rim , rim locks???
24 Aug 2012 12:02
#544486
Did it cut the valve stem off?
Rimlocks are to keep tire from spinning on the rim,unless youre running 10lbs of air in that rear tire and doing burn outs with it I cant see any good reason to run them.
B)
  • Motor Head
  • Motor Head's Avatar
24 Aug 2012 12:05
#544487
I don't see where the 400 came with rim locks on the fiche. Do you have another hole in the rim, same dia as the valve stem? Thats where the lock would fit. Otherwise probably just low pressure, then the tire slips. Either not full enough or a leak/ pinched tube.
24 Aug 2012 13:19 - 24 Aug 2012 13:20
#544500
wireman wrote: Did it cut the valve stem off?
B)
I use them on my KZ650. I did not have them on my BSA and the valve stem was ripped from the tube in traffic. Very scary! So I'm a believer whether I actually need them or not. :) On the BSA I ended up drilling about a dozen holes on each side of the rim and using screws through the rim into the tire bead to prevent slippage (old racer trick). Just be sure the screws aren't too long! :woohoo:
Last edit: 24 Aug 2012 13:20 by 650ed.
  • wireman
  • wireman's Avatar
24 Aug 2012 13:41
#544508
You old street racer Ed! :laugh:
24 Aug 2012 15:33
#544529
What gave me away? :laugh: :laugh:
Attachment BSASHOT.jpg not found
  • wireman
  • wireman's Avatar
24 Aug 2012 16:35
#544545
B) B) B) B) B)
