Mirrors useless
- KZ1000inaus
- Luminous Red KZ1000 A2
Mirrors useless
24 Aug 2012 05:09
My KZ came with a set of mirrors which i imagine are not the original Kawasaki ones as they vibrate so much i cant actually see anything.
Do the real NOS ones actually work?
It's just i can see a set on Ebay for over $100 bucks and i'm not shelling out on them if they are as useless as the pair i have.
Re: Mirrors useless
24 Aug 2012 10:39 - 22 Jan 2013 23:42
The stock mirrors on my 81 KZ650 generally don't vibrate - the right side mirror occasionally does under certain rpms, though. Here's a mirror topic w a couple of KZR links.
KZR - Looking for decent mirrors
Last edit: 22 Jan 2013 23:42 by martin_csr.
- Motor Head
Re: Mirrors useless
24 Aug 2012 10:57
I don't run one, but some say the Bar Snake will cut down the vibration both for the mirrors and your hands. Also check the obvious, loose motor mounts and the like.
- RonKZ650
Re: Mirrors useless
24 Aug 2012 11:18
The stock mirrors on a KZ1000 work great. These are the black colored mirrors. Any other mirror is junk. Most aftermarket are not convex glass. Without the convex glass there is no hope. Here's one of my KZ1000s to see what the mirrors look like stock. KZ650 stock chrome mirrors work, but not half as good as the KZ1000 mirrors.
- Mark Wing
Re: Mirrors useless
24 Aug 2012 12:43
Have to agree with Ron on this one, I have stock 1000 mirrors on my 650 and they work great.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- Mcdroid
- Gone Kwackers
Re: Mirrors useless
24 Aug 2012 12:48
You can get a set of EMGO KZ1000 lookalikes for about US$30...a genuine set of Kawasaki KZ1000 is around US$100...the genuine mirrors are superior to the EMGO mirrors, although they appear superficially similar.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Re: Mirrors useless
24 Aug 2012 13:14Mark Wing wrote: Have to agree with Ron on this one, I have stock 1000 mirrors on my 650 and they work great.
Mark
+1 When I bought my KZ650 the dealer pulled the 650 mirrors off and put on the black KZ1000 mirrors. They work really well. Ed
- peter1958
Re: Mirrors useless
24 Aug 2012 13:20
The stock mirrows have dampers in them. Others dont
www.kzzone.com/
- Sorf
Re: Mirrors useless
24 Aug 2012 21:44
Just on this subject, I recently bought what I thought were stock 1000 LTD mirrors for the short stems. Pulling them apart to repaint the stems I noticed the back of the mirrors are marked as "TOYO"....
would these be the standard mirror?
- KZ1000inaus
Re: Mirrors useless
25 Aug 2012 21:33Motor Head wrote: I don't run one, but some say the Bar Snake will cut down the vibration both for the mirrors and your hands. Also check the obvious, loose motor mounts and the like.
I have noticed more vibrations lately and engine mounts were also on my agenda.
Although the mirrors have always been useless.
Do the original ones say Kawasaki on them or are there any marking to see if they are original or not?
The glass actually moves inside the mirror housing and thats how you adjust angle of rear view. Is this the same as the originals?
- RonKZ650
Re: Mirrors useless
26 Aug 2012 01:41
No the glass does not move on the originals. You need to loosen the mounts. Sounds like you most likely have Chinese "upgrades".
Re: Mirrors useless
26 Aug 2012 09:40
On my originals the glass can be adjusted just a little by pushing in on the edge of the mirror. There are 3 rubber gizmos behind it inside the plastic shell. For anything other than a minor adjustment you must loosen the mounts as RonKZ650 stated. Ed
