Brake shim
  • Prince of polka
  • Prince of polka's Avatar Topic Author
Brake shim
23 Aug 2012 13:12
#544311
Can anyone tell me the thickness of the shim between the front brake pad and caliper is for 77 650 c
77 kz650c
Re: Brake shim
23 Aug 2012 18:18
#544358
Is the part you're after on the diagram?
Attachment 00000_2012-08-23.jpg not found
  • Prince of polka
Re: Brake shim
24 Aug 2012 11:08
#544475
It is the metal plate on the pad #10. It has 2 holes that fit on the pegs of the pad
77 kz650c
Re: Brake shim
24 Aug 2012 11:36 - 24 Aug 2012 11:38
#544482
Wondering how the metal plate came loose from the pad.
Thinking that the metal plate is supposed to be a permanent part of the pad.
And uncertain as to advisability of trying to fab up something to suffice for a missing part of the pad, or whether this would be a safe practice.
As braking is pretty important, would in case of doubt spring for a new pad.
www.z1enterprises.com/ItemDetails.aspx?item=LAFA33
Good Fortune! :)
Last edit: 24 Aug 2012 11:38 by Patton.
  • RonKZ650
  • RonKZ650's Avatar
Re: Brake shim
24 Aug 2012 11:54
#544484
Of course the reason for the pad is to minimize brake squeel. If you brake and don't have problems with excessive noise then no need for the pad.
Re: Brake shim
24 Aug 2012 16:17
#544539
If it's the piece pictured below it is .0016" thick. If you need one I can mail you the one in the pic. Just PM me the address I should send it to. Ed
Attachment BrakePadShim.jpg not found
Re: Brake shim
10 Sep 2012 09:58
#547800
Haven't seen any more postings. Did the shims kill the squeal? Ed
