KZ 1000 Rear Hub / Damper Affect Performance
  • 4TheKZ1000
  • 4TheKZ1000's Avatar Topic Author
22 Aug 2012 21:17 - 22 Aug 2012 21:29
#544173
I was wondering what the forum thought about the performance or not....of the KZ 1000 rear disk brake wire wheel hub. Are there problems with using this combo hub-damper system in a hight performance bike or 1/4 mile passes?
Thanks
Last edit: 22 Aug 2012 21:29 by 4TheKZ1000.
  • wireman
  • wireman's Avatar
Re: KZ 1000 Rear Hub / Damper Affect Performance
22 Aug 2012 21:37
#544181
Id say it makes life easier on the driveline when you drop the clutch hard,but it weighs a ton compared to a spool.
Some turbo guys like a heavier rear wheel to help keep things spooled up. B)
The following user(s) said Thank You: 4TheKZ1000
  • sled
  • sled's Avatar
22 Aug 2012 23:35
#544208
Can you buy new rubber dampers for these hubs ?
  • 4TheKZ1000
22 Aug 2012 23:38
#544210
yep
  • sled
  • sled's Avatar
22 Aug 2012 23:45
#544213
where do you get these from?
  • 4TheKZ1000
22 Aug 2012 23:54 - 23 Aug 2012 00:01
#544217
Last edit: 23 Aug 2012 00:01 by 4TheKZ1000.
  • DiamondSkyBlue1000
  • DiamondSkyBlue1000's Avatar
22 Aug 2012 23:56
#544219
  • 4TheKZ1000
22 Aug 2012 23:58 - 23 Aug 2012 00:01
#544220
I looked at redline...my bad. I fixed it.
  • sled
  • sled's Avatar
23 Aug 2012 01:26
#544231
So you can't get them new for a z1000 hub
new only for LTD ;)
