brake help
- vondikka
brake help
22 Aug 2012 02:29
78 kz650c2. So i just installed my wheels and a new front brake master cylinder( original master didnt have enough clearance on new clubmans) and for some reason, when i tried to bleed the brakes there was no pressure building up, almost no pressure at all when i squeezed the lever. so i tried with the oringinal cylinder and encountered the same problem. I then disconnected the lines from the caliper, and when i squeezed, fluid only dribbled out. I thought maybe the lines were clogged so i disconnected them and blew them out with compressedair. this still didnt solve my problem. Am i missing something? my brakes worked fine before i removed the wheel.
78 KZ650 C2
76 kz400 D3
76 kz400 D3
- wireman
Re: brake help
22 Aug 2012 09:35
Is there a loop in brake line above master cylinder with the club man bars?
- vondikka
Re: brake help
22 Aug 2012 13:15
no, i replaced that section of line with a shorter braided line
78 KZ650 C2
76 kz400 D3
76 kz400 D3
- Del_Herring
Re: brake help
22 Aug 2012 13:34
Just to check, have you bled brakes before, such that you know that you're using the proper procedure? I've definitely seen people try to bleed brakes the wrong way, and you don't get very far. Not meant to be offensive, just figure it's best to start at the simplest solution when troubleshooting.
1983 KZ750-N2 Spectre
- vondikka
Re: brake help
22 Aug 2012 13:39
ive bled many brakes on cars, never a bike.
78 KZ650 C2
76 kz400 D3
76 kz400 D3
- Del_Herring
Re: brake help
22 Aug 2012 14:31
Same procedure really. You've got me stumped then. If you don't mind running through a bunch of brake fluid maybe see if trying the old brake line helps anything. Maybe there's a leak or some such. That's about the only thought I've got though. Hopefully someone else chimes in.
- vondikka
Re: brake help
22 Aug 2012 16:20
yeah , im stumped too. it kinda feels like a leak but i don't see any fluid coming from anywhere.perhaps the lines arent completely full. idk
78 KZ650 C2
76 kz400 D3
76 kz400 D3
- pete greek1
Re: brake help
22 Aug 2012 16:57 - 22 Aug 2012 16:58
are you sure you replaced the crush washers on the top & bottom of the banjo bolts ?...Pete
Last edit: 22 Aug 2012 16:58 by pete greek1.
- vondikka
- vondikka
Re: brake help
22 Aug 2012 19:42
my frustration has reaced its boiling point . nothing is working. there is zero pressure. when i repeatedly squeeze the brake, hold and open the bleeder, the fluid barely trickles out. ihave tried 3 different master cylinders. The caliper pistons don't even move and they are definitely not seized.
78 KZ650 C2
76 kz400 D3
76 kz400 D3
- wireman
Re: brake help
22 Aug 2012 20:25
Did you try bench bleeding the master cylinder?
Ive also left bleeder valve open and just let them gravity bleed themselves to get the process started before,just make sure to keep it topped off and dont touch the lever while the valves are open
- vondikka
Re: brake help
22 Aug 2012 22:25
bench bleeding? I noticed when i take the line off the caliper and pull the lever, the fluid doesn't flow out smoothly . It comes out sporadically, mixed with air, and with very little pressure. This makes me think that all 3 master cylinders I tried are shot. Does this make sense?
78 KZ650 C2
76 kz400 D3
76 kz400 D3
