match engine swap to frame
  • coyotewhisperer
  • coyotewhisperer's Avatar Topic Author
20 Aug 2012 18:44
#543697
I've got a '97 kzp 1000, police bike, and am wondering if the 1200cc engine from the zrx would fit into the '97 frame.
Any ideas out there ?
  • martin_csr
  • martin_csr's Avatar
Re: match engine swap to frame
20 Aug 2012 19:11 - 22 Jan 2013 23:47
#543707
never mind - my error
Last edit: 22 Jan 2013 23:47 by martin_csr.
  • etbike3135
  • etbike3135's Avatar
20 Aug 2012 19:57
#543715
Most late model water cooled engines will not fit KZ frames. The bore spacing is much closer together on newer motors and most have cam chains on the side and not the middle. Problem is on your kz frame your exhaust splits between the down tubes of the frame, a late model motor will have all 4 pipes coming out much closer and the 1 and 4 cylinder will be coming out right into you frame.
1973 Kawasaki Z1
18 years in dragbikes
The following user(s) said Thank You: coyotewhisperer
  • wireman
  • wireman's Avatar
20 Aug 2012 22:43
#543752
Porta power/torch/welder and a lot of extra bracing,anything can be done! :woohoo:
  • porchev914
  • porchev914's Avatar
20 Aug 2012 23:56
#543768
wireman wrote: Porta power/torch/welder and a lot of extra bracing,anything can be done! :woohoo:
X2 Where there is a will there is a way. I wouldn't let silly down tubes get in my way B)
FRANKEN Z!
  • coyotewhisperer
21 Aug 2012 11:58
#543860
The 998 cc engine is fine, with only 18K on it, but I had a chance to pick up a wrecked ZRX w/a good 1200cc engine; so one thought led to another...
  • steell
  • steell's Avatar
21 Aug 2012 16:40
#543935
Use ZZR1200 pistons and cams for even more power in the ZRX1200 motor. :)
  • NakedFun
  • NakedFun's Avatar
21 Aug 2012 17:53
#543942
I can take some measurements off my ZRX if you need them. Other than down tube spacing which may or may not be and issue, personally I would not thik it was much of a hurdle to get that motor in there. All depends on your ability (or willingness to try!) and the tools at your disposal.
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
