Wheel size.??
- petesmith999
Wheel size.??
12 Aug 2012 15:28
Hi all, I' m converting an old kz750 into a bobber, loads of it is rusted away but the baby's running now. Anyone know what is the widest rear wheel I can fit? At the moment we are hard tailing it with struts, with a new frame coming when funds allow it. So the new wheel would have to fit in the existing swinging arm and accept the rear sprocket. Any ideas?
Cheers
Pete
Cheers
Pete
- MFolks
Re: Wheel size.??
12 Aug 2012 15:55
Without getting an offset engine sprocket & wider swingarm, I'd say maybe a 130 x 18 tire.
The following user(s) said Thank You: petesmith999
- 4TheKZ1000
Re: Wheel size.??
12 Aug 2012 18:58
I have a stock width swingarm on mine 9-1/4 inch wide and have a 150 70 18 on with no problems...running all stock sprokets...chain clears sidewall by a 1/4 inch and tracks like butter....
- Je77ekz1000a
Re: Wheel size.??
12 Aug 2012 19:53
I'm squeezing a 130/80/18 in my stock swingarm. But I'm not sure that the width of my rim don't play apart in that, and I'm almost positive it's not factory width.
Jesse Shasteen
77 KZ1000 A
Huntsville AL
77 KZ1000 A
Huntsville AL
- kzz1king
Re: Wheel size.??
12 Aug 2012 20:17
What I would find interesting is the rim width,tire size and actual width of tire at widest part.
Wayne
Wayne
Home built KZ1000 turbo setup
- Nebr_Rex
Re: Wheel size.??
12 Aug 2012 21:20
Which 750?
I have put a 150 on a 13x6 on a KZ650sr and had to modify the swing arm.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- kzz1king
Re: Wheel size.??
12 Aug 2012 22:44kzz1king wrote: What I would find interesting is the rim width,tire size and actual width of tire at widest part.
Wayne
My 130/16 is 5 3/8 wide, rim is 3.25 and I have a 1/2 clerance tween chain and tire. For what it is worth.
Wayne
- 4TheKZ1000
