Du pont Teflon Chain Saver wax based chain lube
  • 4TheKZ1000
  • 4TheKZ1000's Avatar Topic Author
09 Aug 2012 23:41 - 09 Aug 2012 23:44
#541655
has anyone used this product...if so did you like it.
Attachment IMG0625A.jpg not found
Last edit: 09 Aug 2012 23:44 by 4TheKZ1000.
  • Motor Head
  • Motor Head's Avatar
Re: Du pont Teflon Chain Saver wax based chain lube
10 Aug 2012 00:05
#541660
Yes And Yes, seemed like a good lube, still have a can in the rear box/ trunk.
  • dejavoodo41
  • dejavoodo41's Avatar
10 Aug 2012 00:34
#541669
I use it too and like it a lot.
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
  • RonKZ650
  • RonKZ650's Avatar
10 Aug 2012 00:47
#541671
It's good for keeping the bike clean, as a lube it leaves a lot to be desired. I can get 60,000 miles out of a chain properly lubed with regular chain lube. This lube? Maybe 10,000 if you're lucky. Not worth using if you are riding any distance. If you ride a thousand, two thousand miles a year it's OK.
  • Motor Head
10 Aug 2012 00:50
#541673
I've put well over 10K on my 630 chain, mostly using this lube.
  • bountyhunter
  • bountyhunter's Avatar
10 Aug 2012 16:48 - 10 Aug 2012 16:53
#541789
I use it but buy it in the other label because it's cheaper. I love it. Lowe's carries it.
Last edit: 10 Aug 2012 16:53 by bountyhunter.
  • turboking
  • turboking's Avatar
27 Feb 2013 16:03
#574422
bountyhunter wrote: I use it but buy it in the other label because it's cheaper. I love it. Lowe's carries it.
do you buy this one at lowe's ? the Dupont multipurpose :huh: I've been using Maxima chain wax . looking for something cheaper that works as well :laugh: :laugh:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
  • martin_csr
  • martin_csr's Avatar
27 Feb 2013 17:42 - 28 Feb 2013 13:01
#574430
webBikeWorld didn't seem to care much for the Chain Saver. The DuPont Multi-Use Dry Wax lubricant isn't available any more. wBW didn't give their new Mulit-Use product a very good review & DuPont does not recommend it for mc chains.
webBikeWorld review
Last edit: 28 Feb 2013 13:01 by martin_csr.
The following user(s) said Thank You: turboking
  • turboking
27 Feb 2013 18:02
#574436
Thanks, guess I will stick :blink: with chain wax........
1985 GS 1150E
1983 GS 1100E
  • donthaveakawman
  • donthaveakawman's Avatar
27 Feb 2013 18:09
#574439
I am curious if it is difficult to clean.
27 Feb 2013 20:04
#574461
turboking wrote: Thanks, guess I will stick :blink: with chain wax........
I use Maxima Chain Wax too - it works well. Ed
  • donthaveakawman
27 Feb 2013 22:12
#574480
I used one in a container similar to that recently, my big can ran out. I found that using a piece of vacuum hose on the tip of the bottle it is possible to oil the inner side of the chain on the sprocket
