Idle change with wheel turn
- mind2find
13 Jun 2006 05:51
The Bike Runs!!! First ride last night. Lots of smoke to start but I'm assuming it just needed to be burnt off.
ANYWAY:
I know I've seen the answer to this around somewhere but couldn't find anything when searching. The idle cranks up when I turn the handlebars all the way to the right. How should I be adjusting my accel/decel cable set-up to prevent this??? This is the one real issue I see after starting her up for the first time. My day off tomorrow has never seemed so full of potential. :woohoo:
ANYWAY:
1976 KZ-750B1 (late model)
1976 KZ-750B1 (early model) Parts Bike
Boston, MA
Boston, MA
- OKC_Kent
Re: Idle change with wheel turn
13 Jun 2006 06:31
Check this link out, about throttle cable adjusting. Similiar information is in the manual too.
kzrider.com/component/option,com_joomlab...id,3/id,11774/#11774
Cashion, OK
78 KZ650 B2 85,000+ miles
- cnyl
13 Jun 2006 07:06
Easy fix. You'll be zoomin around on that twin in no time.
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
North Port, FL
Check out my band
- cnyl
13 Jun 2006 07:07
Oh.... What color smoke? Did the smoke go away?
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
North Port, FL
Check out my band
- Pterosaur
13 Jun 2006 07:13
mind2find wrote:
From the sound of it, rather than it being a cable adjustment issue, it may be the throttle cable binding up somewhere, perhaps under the tank...
You turn the bars to the right, the idle chnages - it doesn't take much deflection of the cable to cause a noticeable change - you didn't say how much.
If the cable is being pinched, it could be locking the sheath against the core and giving it a tug.
Not a for-sure fix, but a possibility to look into...
...The idle cranks up when I turn the handlebars all the way to the right. How should I be adjusting my accel/decel cable set-up to prevent this???
- steell
13 Jun 2006 07:21
Normally that problem is caused by improper cable routing, whenever I install new cables I always start the bike and turn it lock to lock to make sure they are routed right.
- mind2find
13 Jun 2006 07:25
It was dark out by the time i got it started so I'm not sure on the color of the smoke. Seemed just white. I'll certainly pay attention next time if it persists. Yes, it did go away after a few minutes of idling though. *phew*
I'll definitely check the routing. I just realized I may not have lubed the accel/decel like I had intended so that's another thing.
Thanks for the tips! Will have pics soon!
Boston, MA
Boston, MA
